crank stroke fro b18c block
Old Dec 11, 2006 | 11:30 AM
Del Sol on Steroids's Avatar
Default crank stroke fro b18c block
what the longest stroke I can go on a b18c block,?
Old Dec 11, 2006 | 01:12 PM
doood's Avatar
been there done that
Default Re: crank stroke fro b18c block (Del Sol on Steroids)
you dont need to make two threads on the same topic
Old Dec 11, 2006 | 01:35 PM
95 integra's Avatar
Default Re: crank stroke fro b18c block (that one doood)
https://honda-tech.com/zerothread?id=1833707
https://honda-tech.com/zerothread?id=1834266
https://honda-tech.com/zerothread?id=1834646
https://honda-tech.com/zerothread?id=1834719
Do you not like the information being given to you or are you just so stupid you cant read the other 4 threads you started where people have told you time and time again that 95mm is the most. If 95mm isnt enough for you, then get somebody to custom make you a 120mm crank.
Old Dec 11, 2006 | 01:54 PM
i started asking around 8:30, no one was answering so i ask in different forums. But thanks alot, I didnt want to buy something that will not work on me.
BlkSIvic
Dec 25, 2003 08:54 PM
SiRkid
Jun 9, 2002 09:32 AM
I-VTECRX
Jan 23, 2002 04:58 AM
