DA suspension parts for crx?
Old Dec 11, 2006 | 11:12 AM
russianswty's Avatar
Default DA suspension parts for crx?
I need to know if im suppose to use these parts of the da on the crx while
doing the front and back brake conversion.
The hand brake cables? They seem to be a lot longer
The lower control arms. Front and back.
And any other parts im suppose to keep of the crx, or da?
Old Dec 11, 2006 | 11:22 AM
89efDUSTY's Avatar
Default Re: DA suspension parts for crx? (russianswty)
E brake cables must come from DA they fit...i did it to my car...LCA i have the stock CRX ones...but i believe DA even Stock ITRs will fit...good luck...
Old Dec 11, 2006 | 11:45 AM
Tyson's Avatar
Default Re: DA suspension parts for crx? (89efDUSTY)
DA rear LCA will fit but are not the same and not recommended.
basically, dont use any control arms from the DA on a CRX. just use the knuckles and trailing arms.
Old Dec 11, 2006 | 12:25 PM
Default Re: DA suspension parts for crx? (Tyson)
Would ef cables not work on my ef with the da brakes?
I know somebodies tried this and either has succeded or failed.
And the extra piecies on the end of the trailing arm,
And the part that attaches the brakes to the frame right behind
the suspension?
Are those supposed to be ef parts?
Old Dec 11, 2006 | 04:05 PM
mahatma's Avatar
use DA cables,
ED compensator arms (dogbone looking pieces)
ED LCA's
Old Dec 11, 2006 | 04:13 PM
Default Re: DA suspension parts for crx? (mahatma)
what model is the ed?
Old Dec 11, 2006 | 04:15 PM
Loserkidwac's Avatar
ED=USA
EF=JDM
ziurek filmus
May 14, 2017 07:29 AM
89ED
31
Jun 14, 2013 01:36 PM
EFjoe91
11
Feb 9, 2010 11:13 AM
russianswty
39
Jan 25, 2007 12:02 PM
Coppertop
Dec 24, 2006 09:14 PM
