Catalytic converter questions.. fitment
Would a Cat. converter with a 2.5" inlet/outlet fit and line up with the Greddy EVO2's 60mm(2.35") B-Pipe fine? This is assuming that the converter's length is the same length as the OEM one.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evo1234 »</TD></TR><TR><TD CLASS="quote">Would a Cat. converter with a 2.5" inlet/outlet fit and line up with the Greddy EVO2's 60mm(2.35") B-Pipe fine? This is assuming that the converter's length is the same length as the OEM one.
Thanks.
If it's made to the correct length, The real question is what header are you running? If it's a usdm, then you should go with a 2-1/4" cat. The IDs will then match up at your B pipe, assuming your Greddy doesn't have a bottle neck there.
Thanks.
</TD></TR></TABLE>If it's made to the correct length, The real question is what header are you running? If it's a usdm, then you should go with a 2-1/4" cat. The IDs will then match up at your B pipe, assuming your Greddy doesn't have a bottle neck there.
evo1234
Dec 11, 2006 08:52 AM
chameleon30038
Oct 6, 2005 05:23 PM
turboex
Jan 13, 2002 07:42 PM
