oversized valves?
Old Dec 11, 2006 | 06:54 AM
CXtypeR's Avatar
Default oversized valves?
any benefit going with .5 or 1mm oversized valves on a stock port jdm itr head and m22x cams on a bone stock block?
Old Dec 11, 2006 | 07:14 AM
GO-FIGHT-KILL's Avatar
What pistons are you using? Might not want to go oversized with cams and high CR pistons...
Old Dec 11, 2006 | 07:24 AM
CXtypeR's Avatar
stock 11:1 pistons
any benefit with oversized?
Old Dec 11, 2006 | 07:26 AM
RTW DC2R's Avatar
Default Re: (CXtypeR)
you cant just put oversized valves in and go, you have to have the valve seats machined. you are better off contacting head builders and get their opinion. headgames, import builders, etc. i would say the stock head flows well enough that you probably wont see a difference without substantial headwork.
Old Dec 11, 2006 | 07:28 AM
CXtypeR's Avatar
Default Re: (RTW DC2R)
i think ill just stick with my oem ones. $200 in my pocket
Old Dec 11, 2006 | 07:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">you cant just put oversized valves in and go, you have to have the valve seats machined. you are better off contacting head builders and get their opinion. headgames, import builders, etc. i would say the stock head flows well enough that you probably wont see a difference without substantial headwork. </TD></TR></TABLE>
^ Good advice.
You have a JDM Type-R engine, I assume (11:1CR)? Honestly, if I were you, I'd just run stock valves, they're fine. I would just spend the money on some good titanium retainers, valvesprings, a 1-layer headgasket, and a good tune.
Old Dec 11, 2006 | 07:37 AM
CXtypeR's Avatar
Default Re: (GO-FIGHT-KILL)
im thinking about if its worth going with std size flat valves and a 1 layer oem headgasket
is the extra $300+ worth the bump in compression from the 11:1 for use with m22x?
and how much compression bump will the 1layer give me on my setup?
Modified by CXtypeR at 11:55 AM 12/11/2006
Old Dec 11, 2006 | 10:01 AM
1-Layer Headgasket should bump you up about .5CR. Which woulld be perfect for those cams.
Old Dec 11, 2006 | 10:07 AM
CXtypeR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">1-Layer Headgasket should bump you up about .5CR. Which woulld be perfect for those cams. </TD></TR></TABLE>
which part of the HG would bump up .5?
so flat valves and 1layer HG = 11.8?
Old Dec 11, 2006 | 10:13 AM
I'm not sure about the valves... I'd just keep stock valves with a 1-Layer Headgasket, save some money, and you won't lose much performance between the two valves.
Old Dec 11, 2006 | 10:19 AM
crxgator's Avatar
if you daily drive the car do not get ti retainers...
Old Dec 11, 2006 | 10:26 AM
CXtypeR's Avatar
Default Re: (crxgator)
according to rocket, retainers that are snap fit on matching springs prevent excess wear
Old Dec 11, 2006 | 11:04 AM
EG2Driver's Avatar
i've heard that before....why not?
Old Dec 11, 2006 | 11:31 AM
neo_'s Avatar
Default Re: (DeadEnd9009)
You will be limited by cam choices and will need to worry more about piston valve clearence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">if you daily drive the car do not get ti retainers...</TD></TR></TABLE>
You can pull it off, just make sure you take off the valve cover at regular intervals and check them. Ferrea retainers are some of the best IMO, and I haven't had a single issue daily driving with them for 20k miles so far.
Old Dec 11, 2006 | 11:38 AM
GUILOTINE's Avatar
Kill Gil
Default Re: (neo_)
Tom at Portflow doesn't recomend O.S. valves for NA applications.
Old Dec 11, 2006 | 11:45 AM
RTW DC2R's Avatar
Default Re: (GUILOTINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUILOTINE &raquo;</TD></TR><TR><TD CLASS="quote">Tom at Portflow doesn't recomend O.S. valves for NA applications.</TD></TR></TABLE>
Im telling you, take advice from the guys that make a living building heads.
Old Dec 11, 2006 | 12:07 PM
CXtypeR's Avatar
std size it is.
Old Dec 11, 2006 | 01:04 PM
^ Worrrrd.
Good call man.
Old Dec 11, 2006 | 04:22 PM
BABY NSX's Avatar
Gord Bush does
Old Dec 11, 2006 | 07:08 PM
d.n.d.'s Avatar
Default Re: (neo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ &raquo;</TD></TR><TR><TD CLASS="quote">You can pull it off, just make sure you take off the valve cover at regular intervals and check them. Ferrea retainers are some of the best IMO, and I haven't had a single issue daily driving with them for 20k miles so far.</TD></TR></TABLE>
if you dont mind me asking, check for what exactly? signs of wear?
Old Dec 11, 2006 | 09:13 PM
neo_'s Avatar
Default Re: (d.n.d.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d.n.d. &raquo;</TD></TR><TR><TD CLASS="quote">if you dont mind me asking, check for what exactly? signs of wear?</TD></TR></TABLE> https://honda-tech.com/zerothread?id=795870
wunfstgsr
Jun 16, 2008 04:33 PM
gs1gsr
Jan 13, 2008 09:20 AM
urtz
Jun 18, 2007 01:30 PM
lyckaon
Nov 20, 2005 11:05 PM
gsrjay
Sep 2, 2004 05:05 AM
