Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rusty Brake rotors
Old Dec 11, 2006 | 05:03 AM
SickSpd06Si's Avatar
Default Rusty Brake rotors
It's like everytime I wash my car the brake rotors rust up. Actually not just when I wash it. Anytime my rotors get wet they looks all rusty, not where the pads touch. Am I the only one with this problem?
Old Dec 11, 2006 | 05:20 AM
WILD_WILL's Avatar
Default Re: Rusty Brake rotors (SickSpd06Si)
It happens to me like every other wash and i wash my car like twice a week i think there is some kind of brake dust spray out there if you find it let me know !
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SickSpd06Si &raquo;</TD></TR><TR><TD CLASS="quote">It's like everytime I wash my car the brake rotors rust up. Actually not just when I wash it. Anytime my rotors get wet they looks all rusty, not where the pads touch. Am I the only one with this problem?</TD></TR></TABLE>
http://en.wikipedia.org/wiki/Oxidation
vs
http://en.wikipedia.org/wiki/Rust
Old Dec 11, 2006 | 06:12 AM
Demonis's Avatar
if im not mistaken, every car does this....
Old Dec 11, 2006 | 06:55 AM
Default Re: (Demonis)
Antone running aftermarket rotors. if so what kind and how much where they. I'm looking to buy some new ones that will hopefully not do this.
Old Dec 11, 2006 | 09:10 AM
HondaF1Fanatic's Avatar
Every brake rotor will do this (even the aftermarket ones after the nickel/whatever plating comes off). If you want a rotor that won't rust you are looking at Carbon, Ceramic, or Titanium rotors which will all cost more than your car (if you can even find a kit). Don't worry about the rust, it goes away as soon as you apply the brakes for one full revolution of the rotor.
Jon
Old Dec 11, 2006 | 10:24 AM
Default Re: (HondaF1Fanatic)
I know most brake rotors will rust but it just seems like the rotors on this car rust a lot more than usual.
Old Dec 11, 2006 | 10:55 AM
d16dcoe45's Avatar
Default Re: (SickSpd06Si)
As soon as you drive the car for 2 minutes or more--assuming you have to use the brake at some point, the rust will be gone. I find it hard to believe that a Civic Si does it more than other cars with cast iron rotors.
Old Dec 11, 2006 | 11:27 AM
Default Re: (d16dcoe45)
it's not where the pads touch. it's the part that is vented. the thin part on the outside.
Old Dec 11, 2006 | 01:01 PM
d16dcoe45's Avatar
I suppose if you are really that concerned about it the best thing to do would be grind all the rust off of the offending area, mask the part of the rotor you don't want painted, and use some high-heat exhaust or BBQ paint to cover the area. no rust. You can also do this to the "hat" the part that the wheel mounts to.
Old Dec 11, 2006 | 02:31 PM
Can I use the same stuff you would paint your brake caliper with????? I'm not really worried about it. I just dont like how it looks. The only thing is after i wash my car some of the rust gets on my rimes. and with having white rims it stands out so much.
Old Dec 16, 2006 | 12:35 PM
galaxyex's Avatar
I found that if you make sure your rotors are on the cooler side they dont tend to get that thin rust layer on them when they get wet from washing. Also if you use a spray cleaner on your rims be careful not to get back onto the rotors that makes it worse it seems.
Old Dec 16, 2006 | 02:40 PM
d16dcoe45's Avatar
Default Re: (galaxyex)
Use the VHT stuff--its like $8-9 a can and they have a flat black version. I believe its good to 900 degrees. My drums came raw cast iron--unpainted, so I used the VHT flat black paint--holds on well--no more rust.
Old Dec 16, 2006 | 04:32 PM
gus738's Avatar
brake dust will be off once you drive or all sudden hits brake hard! you can also use a steamer and it drips it away within secs then once dried silver finish :D
Old Dec 16, 2006 | 05:24 PM
L-Dawg's Avatar
As I looked at the pictures my friend took when I was picking up my BRAND NEW, 2007 si with 10 miles on it, I noticed rust on the edges of my discs. Ugh.
teggsr925
Mar 3, 2007 01:35 PM
Understeer
Suspension & Brakes
10
Mar 21, 2006 07:08 PM
jorge99hx
25
Dec 10, 2005 12:52 PM
Ex-ITR5874
Feb 29, 2004 08:01 AM
