Knocking noise
Old Dec 11, 2006 | 04:33 AM
garyc17's Avatar
Default Knocking noise
I'm getting this knocking sound when i go over a speed hump at an angle. When the first front wheel touches the hump, it knocks once and knocks again when the other front wheel touches it. There is no noise from the rear. What could be the problem?
Old Dec 11, 2006 | 06:39 AM
MidwestSiR's Avatar
blown shock maybe? front endlink is broken? give us some specs on your car.. if it's modded or not..
Old Dec 11, 2006 | 06:43 AM
RTW DC2R's Avatar
check the front sway bar
Old Dec 11, 2006 | 10:55 AM
garyc17's Avatar
I'm on Tein coilovers. The knocking only happens when I go over humps. There are no problems travelling on normal street roads.
What should I look out for in the front sway bar? Broken endlinks?
Old Dec 11, 2006 | 11:31 AM
MidwestSiR's Avatar
yeah, worn/cracked bushings and broken endlinks.
are you slammed on the coilovers?
Old Dec 11, 2006 | 08:36 PM
MidwestSiR's Avatar
any news/updates?
Old Dec 11, 2006 | 11:17 PM
garyc17's Avatar
I am not slammed on the coilovers. There is about half an inch gap between wheel and fender. My endlinks are not broken.
Would this mean my lower arm bushings require replacements? Any definite way to check this? Can steering rack bushings be the cause?
Old Dec 12, 2006 | 05:34 AM
RTW DC2R's Avatar
any of those bushings can cause this. jack the front of the car up in the air and start wiggling the wheels, top to bottom and side to side.
Old Dec 12, 2006 | 10:03 AM
MidwestSiR's Avatar
can you feel the knock in the steering wheel?
Old Dec 14, 2006 | 09:38 AM
garyc17's Avatar
I shook the front wheels and it seems there is no slack or free play. The knock seems to be coming from the steering column but I could be wrong. If that is the location of the noise, what is the problem?
Old Dec 14, 2006 | 09:50 AM
totsie7944's Avatar
Default Re: (garyc17)
is it a metal on metal sound?
Old Dec 14, 2006 | 11:46 AM
garyc17's Avatar
It doesn't have a metallic knocking sound. It goes something like "kok kok" if you try to pronounce the word.
Old Dec 14, 2006 | 03:26 PM
MidwestSiR's Avatar
hmm.. is it louder inside the car other than out? roll down your window. No idea what it could be if it's coming from the steering column area..
Old Dec 17, 2006 | 08:02 AM
garyc17's Avatar
I was thinking of replacing the 4 vertical bushings and the circular one for the rack.
stevenbr549
Nov 23, 2014 11:16 PM
06mmDc5
Dec 6, 2012 09:46 PM
mr_munro
Suspension & Brakes
31
Feb 25, 2012 10:52 PM
Blade_Irl
Suspension & Brakes
Dec 27, 2008 01:21 PM
Casual Gcode1
Feb 8, 2003 12:15 PM
