intake manifold
Old Dec 10, 2006 | 09:08 PM
the king.'s Avatar
Default intake manifold
hey i was on ebay and i saw this
does it really work? like does it give the boost it promises? and if it does is it noticable
Old Dec 10, 2006 | 09:10 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: intake manifold (the king.)
You are better off running an y8 mani then something like that.
It may or may not help and if so it wouldn't be much.
y8 is cheap and proven gain, what is your setup though as an intake mani might not be best bang for buck?
if you want to do an intake mani most any setup will be fine with a y8
linky for install
http://www.geocities.com/joeyp....html
Old Dec 11, 2006 | 06:00 AM
Got_soy's Avatar
those thing are trash, there are dyno sheets were they actually cost power. word on the street is that they lloke to break also
Old Dec 11, 2006 | 06:38 AM
Civiclized's Avatar
The truth is these aren't all that bad if your car is built for low end.This type of manifold allows high h.p. motors to be feed thier air supply quicker.The down side is that torque is usaully built up by using longer runners on the maniold.Thus why a Y8 would work better per a street application of a non boosted motor with a mid range power band.
Just a side note:
Longer runners on the intake manifold = cooler air entering the combustion chamber, and more torque.
Shorter runner on intake manifold=Warmer air entering the combustion chamber , less torque.
crxtech87
Feb 16, 2013 08:44 AM
lorenzookc
May 22, 2011 04:37 PM
silver99
Jun 5, 2003 02:45 PM
russian_racer
Mar 19, 2003 11:06 PM
