Does A 96-00 Radiator fit 89 ef Hatch????? HElp
Old Dec 10, 2006 | 09:03 PM
efinitup's Avatar
Default Does A 96-00 Radiator fit 89 ef Hatch????? HElp
Whats up I need some info tryin to buy a 96-00 aftermarket radiator but, I need to know if it will fit my 89 Ef which has a d16 in it. Any info is helpful. Thanks!
Old Dec 11, 2006 | 06:07 AM
RockinthEFhatch's Avatar
Default Re: Does A 96-00 Radiator fit 89 ef Hatch????? HElp (efinitup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx303 from tuner-junction.com &raquo;</TD></TR><TR><TD CLASS="quote">
The reason why I did this install was non-availability and/or sky-high prices for an EE8/EF8/SiR radiator.
Take a small angle grinder and a Dremel and cut this piece out of the front chassis:
Finish, spray, put tectyl and some rubber to protect the bottom of the radiator. I used some vacuum hoses and cut it lengthwise:
A bracket on top from aluminium strip:
This setup works best with a slim fan:
Finished install, hood closes smoothly. The original pilars for the bracket on the radiator top and bottom have to be cut.
When connecting the bottom hose I found out that a small piece of the cross member need to be cut also to fit the hose. The hoses and the bracket keep the radiator firm in place.
NOTE: this install was done on a SiR. I don't know about fitment on other types, without the SiR hood.
This should help a little.
Old Dec 11, 2006 | 06:31 AM
shortyz21's Avatar
Default Re: Does A 96-00 Radiator fit 89 ef Hatch????? HElp (RockinthEFhatch)
i HAD the same setup. it was put in the same way as crx2003's is.
for the filler neck to clear sometimes u gotta chop up the hood also.
Old Dec 11, 2006 | 09:29 AM
efinitup's Avatar
Default Re: Does A 96-00 Radiator fit 89 ef Hatch????? HElp (shortyz21)
Awesome man thanks that was more info than I was hoping for. Thanks guys.
Old Dec 11, 2006 | 10:54 PM
EF9 JAMS!!!'s Avatar
THAT IS EFFING AWESOME~!!!!!!!!!
Old Dec 12, 2006 | 05:59 AM
Chronicsinners's Avatar
nice job on that install Buying my Civic rad right now!
Old May 18, 2011 | 10:12 PM
bufalo123's Avatar
nice set up bro..wish mine was like that :/
GILBY
Apr 11, 2016 08:54 AM
alexEF
33
Apr 6, 2010 09:26 AM
EF9_RIDER37
Apr 3, 2010 08:57 PM
iwhichisme
May 4, 2004 09:07 PM
Nerologic
Nov 5, 2003 10:44 PM
