gsr intake manifold b16 head
Old Dec 10, 2006 | 08:55 PM
92b16si's Avatar
Default gsr intake manifold b16 head
I posted this on the hybrid section but no response and im sort of in a hurry.
I did a search and found mix reviews .Im trying to install a gs rintake manifold into a b16 head because its ported and was cheaper then a skunk2. It is already tapped to fit the pr3 head but the water passage doesnt match so it is blocked off. Is this water passage really that important or will it be ok to be blocked off.
Old Dec 10, 2006 | 09:25 PM
SiB16A's Avatar
Default Re: gsr intake manifold b16 head (92b16si)
Why use a gsr manifold? No it does not fit, people usually ditch the gsr manifold anyways. On a b16 head you can get a ITR intake manifold or something along those lines.
Old Dec 10, 2006 | 09:41 PM
92b16si's Avatar
Default Re: gsr intake manifold b16 head (SiB16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A &raquo;</TD></TR><TR><TD CLASS="quote">Why use a gsr manifold? No it does not fit, people usually ditch the gsr manifold anyways. On a b16 head you can get a ITR intake manifold or something along those lines.</TD></TR></TABLE>
I got it beacuse it was cheap and port and polished to 68 mm.
and i got it for 150 instead of 200+ for a itr one
Old Dec 10, 2006 | 09:55 PM
SiB16A's Avatar
even if it's been ported it does not fit the b16 head. The gsr intake manifold bolt pattern does not line up with the b16/itr heads.
Old Dec 11, 2006 | 04:32 AM
b19coupe's Avatar
Erick used to run a GSR intake manifold on his Pro all motor car. He was running a B16 head. The water passage is not critical, you will be fine without it.
Old Dec 11, 2006 | 04:37 AM
1 2 NV's Avatar
Default Re: gsr intake manifold b16 head (b19coupe)
the only other thing i can think of is the GSR IM better be port matched to the B16 head because the ports look totally different and you will lose airflow when its mated to the B16 head. the GSR has a "higher" port throat for lack of better terms.
Old Dec 11, 2006 | 11:27 AM
92b16si's Avatar
it is tapped to fit a b16 head and i lined up the holes from the intake manifold to the b16 head and the ports seem to line up right
Old Dec 11, 2006 | 04:52 PM
1 2 NV's Avatar
look at the ports man, pay attention to what i said in the last post.
JDM RHD eg6
Jan 18, 2007 01:39 PM
db1b18c
Aug 11, 2005 11:43 PM
da'ee
Feb 3, 2005 09:49 PM
AK94GSR
38
Nov 29, 2004 09:42 AM
