Center Caps for 97 SE Honda Accord with Alloy Wheels
My daughter has a 1997 Honda SE Accord with Alloy Wheels and needs the center caps. I believe the part number is 44732-SV7-A00. They run about $28 a piece from the dealer. What I was wondering, can other center caps work, as long as the size is correct or are the tabs longer on one versus the others? You can find other caps alot cheaper just not that part number. Thanks..
Have you tried checking out Handa or something along those lines? Check out the Accord FAQ for the links to the online Honda stores, you can probably get them cheaper than that.
But yes the caps should fit from other models, though I"m not sure which other cars have the same caps. People do it all the time with ITRs with the A to H emblems etc
lol yeah much cheaper
EDIT* Make sure this following link works for you, I double checked it and it works only $5 a cap from there
http://www.hondaautomotivepart...umber+
Thanks for the info...that product number, does that match the honda number I need or is this one that will fit? Again, thanks... my daughter will be happy to get these.
Jimmy
Jimmy
Yep that's the exact product number you listed, if you want to double check just go to the base site of http://www.hondaautomotiveparts.com and to a parts catalog and enter in the part number. But what I listed should be exactly what you need.
