throttle pulley on blox manifold...(searched)
i installed a blox intake manifold on my 98 gsr, i have the stock TB and oem throttle cable, my buddy and i were trying to put the ITR cable and bracket, but the pulley is not the same....do i have to buy the itr TB? or do i have to go waiste my time and try to find the ITR pulley itself....
how about a b16 pulley..or TB?...
yes you need the rotor from a b16, ls or itr. maybe others, i dunno. but the gsr throttle cable loops around to the other side, so the rotor is different.
Yep, you can use a LS TB or change the pulleys out. I think there was somebody that was milling out the pulleys awhile back....so if you could just buy that pulley that'd work as well. Also, most of the aftermarket TBs have dual pulls so it can work on either on.
strongarm1731
Dec 13, 2005 09:49 PM
