Opinions on repairing this header !!!
Old Dec 10, 2006 | 04:02 PM
buda18's Avatar
Default Opinions on repairing this header !!!
bottom side of the header
the inside of the header (nearest to block)
how would you guys go about in repairing this header.
it's a moogen so i'd like to save it, if at all possible. thanks
Old Dec 10, 2006 | 04:11 PM
standbackimapro's Avatar
You could, cut out the damaged area.. then just weld new pieces in...
Its not easy to repair..
Old Dec 10, 2006 | 05:22 PM
.RTErnie's Avatar
Default Re: (standbackimapro)
you'll need to seal both sides of the header. The o2 bungs, head flange, and the outlet. with a gasket and a steel plate. MAKE SURE it doesnt leak. weld on an air fitting for your air compressor.
Pressurize the inside of the header.... to 60-80 psi
now take a a rosebud and SLOWLY and CAREFULLY heat it. The pressure on the inside will push the crushed parts out.
Old Dec 10, 2006 | 05:40 PM
jamheg1101's Avatar
we do it with motorcycle exhausts all the time just like erik said, except we don't use compressed air.
Old Dec 10, 2006 | 05:52 PM
9bells's Avatar
OG Fabricator
Default Re: (jamheg1101)
What do you use, nitrogen???
That's a neat trick, I did it the hard way, cutting and welding.
I see this all the time on the domestics...
Thanks, learned something very useful today!
Old Dec 10, 2006 | 06:44 PM
AllmotorEH2's Avatar
Default Re: (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, learned something very useful today! </TD></TR></TABLE>
x2
Old Dec 10, 2006 | 07:58 PM
EJgsr's Avatar
Default Re: (AllmotorEH2)
weld a bolt to the dents and heat up the area that is dented and pull it out and cut the bolts off and grind smooth... works very well...
Old Dec 10, 2006 | 10:53 PM
NUISANCE's Avatar
Couldn't you pull a ball through it while heating it? It will have to be a ltiile smaller than the opening to get it through. Isn't that what they do for mandrel bends?
Old Dec 11, 2006 | 05:32 AM
8mpg's Avatar
Default Re: (NUISANCE)
when they make mandrel bends they usually use a spring lookin thing on the inside when they bend it. It doesnt allow the tube to crush
Old Dec 11, 2006 | 08:42 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (8mpg)
or they pack the tube with styrofoam or sand
Old Dec 11, 2006 | 08:47 AM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NUISANCE &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't you pull a ball through it while heating it? It will have to be a ltiile smaller than the opening to get it through. Isn't that what they do for mandrel bends?</TD></TR></TABLE>
what the hell??? what happens when the ball gets stuck???
Old Dec 11, 2006 | 08:48 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (USDMej1)
cut the tube and pull it out
Old Dec 11, 2006 | 09:38 AM
50SaysHeEatsIt's Avatar
Default Re: (Eric@HorsepowerFreaks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eric@HorsepowerFreaks &raquo;</TD></TR><TR><TD CLASS="quote">you'll need to seal both sides of the header. The o2 bungs, head flange, and the outlet. with a gasket and a steel plate. MAKE SURE it doesnt leak. weld on an air fitting for your air compressor.
now take a a rosebud and SLOWLY and CAREFULLY heat it. The pressure on the inside will push the crushed parts out. </TD></TR></TABLE>
Great Stuff
Old Dec 11, 2006 | 10:19 AM
NUISANCE's Avatar
Pull it back out the other way or hit it with compressed air. The ball thing was just a thought.
Old Dec 11, 2006 | 10:49 AM
8mpg's Avatar
they do it when making mandrel bent copper tubings for instruments. You bend the metal with a regular bender then they shove metal ***** through the tubing. THey use a ball thats the size of the inside diameter of the tubing then use a few smaller ones to push the big one all the way through. The big thing that allows this to work correctly, the tubing is put in a metal form that holds the tubing perfectly. When the ball travels through, it has to follow the path and only allows the metal to press out on the sections where it has bent in...
Old Dec 11, 2006 | 01:08 PM
buda18's Avatar
Default Re: (8mpg)
wow. so this process definitely recquires more knowledge of fabrication than i have. how much would such a thing cost?
Old Dec 11, 2006 | 03:23 PM
Mykizism's Avatar
bondo it, and repaint FTFW!!! haha
Old Dec 12, 2006 | 07:35 AM
8mpg's Avatar
Default Re: (buda18)
the ball thing?
You gotta have the metal backing to do it... they use a block of steel/aluminium, cut the thing in half and machine out 1/2 the bend on each side... Then they put the tube in the block of metal put it in a vice so it cant move..then they use the metal ***** to expand the pipe. You cant really do it at home as a repair..its more of a manufacturing thing.
Old Dec 12, 2006 | 05:49 PM
cua0's Avatar
you are probably better off using it as scrap. lol.
a new header is worth less than that thing would be to repair.
what kind of header is it that makes you want to try to repair it rather than cutting it up in to tiny little bits and throwing them at your friends and enemies?
Old Dec 12, 2006 | 06:37 PM
buda18's Avatar
Default Re: (cua0)
yeah i just wanted to see if it's worth saving. if not, i'll probably just sell it on ebay for however much i can get out of it. not too worried about it.
Old Dec 12, 2006 | 10:58 PM
F20Cteg's Avatar
Cut off the engine flange and sell it. You could also sell the collector part.
Old Dec 13, 2006 | 06:59 AM
onefstek's Avatar
DC sports collecors are not worth anything.
IMHO, just get another header. Not worth the time or money to fix it.
Old Dec 13, 2006 | 04:16 PM
buda18's Avatar
Default Re: (onefstek)
but it's not a DC header. it's a Mugen header
Old Dec 13, 2006 | 04:38 PM
Black Paper Diary's Avatar
could try a stud welder and slide hammer if you have access to one. I dont know if it will work, but it's worth a shot.
Old Dec 16, 2006 | 07:23 PM
trrbl1bmx's Avatar
Heat and Use compressed air to pull it back together... I've seen it work on far too many headers, we saved an old school T1R like that.
starcraftbw
Aug 2, 2007 11:03 AM
98vtec
Welding / Fabrication
Mar 17, 2005 06:37 PM
JDMlyfestyle
Jul 16, 2004 11:26 PM
revhrdls
May 15, 2002 09:45 AM
