****Help on brake issues!! ASAP
Old Dec 10, 2006 | 01:58 PM
sleeperrex's Avatar
Default ****Help on brake issues!! ASAP
hi
rite now my brake pedal goes to the ground and doesnt do jack....we tried bleeding it. my friend loosened the lines and i press and pumped it a coulple times then held it and he retightened it. we did it to both sides. this is how u do it right??
yet the brakes still hit the ground
and on another note, on the rite passsenger side when i jack the car up and can wiggle the rotor which is not suppose to happen and which i cant do on left side. any explanations?
Old Dec 10, 2006 | 02:00 PM
BlueIntegraBoy's Avatar
Default Re: ****Help on brake issues!! ASAP (sleeperrex)
You might have a leak somewhere if your brake pedal just becomes soft out of nowhere.
Secondly, the rotor is wiggling because of a bad wheel bearing.
Old Dec 10, 2006 | 02:12 PM
Brick Top's Avatar
Default Re: ****Help on brake issues!! ASAP (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
Secondly, the rotor is wiggling because of a bad wheel bearing.</TD></TR></TABLE>
the rotor is probably wiggling because there arent any screws there to hold it to the hub. and check your fluid reseviour and see if you have fluid in it.
Old Dec 10, 2006 | 02:22 PM
blinx9900's Avatar
Default Re: ****Help on brake issues!! ASAP (brick top)
if the screws are tight it is the wheel bearing for sure... are you making sure that there is still fuid in the MS while your gleeding?
Old Dec 10, 2006 | 07:27 PM
sleeperrex's Avatar
Default Re: ****Help on brake issues!! ASAP (blinx9900)
yep made sure fluid is there. and my screws on rotor are tight so i guess its a bad bearing. its dark and drizzling so i think ill redo bleeding my brakes tomorrow.
on another note again...i have extended studs and as my friend was tightening on a lug nut it wouldnt anymore cuz the stud was moving with it...i was like WTF . so do i need new studs or jus need to go to a shop to hav them redo it?
keith1993may
Apr 16, 2013 04:33 PM
Fuzbal
Honda Civic (2001 - 2005)
Jul 12, 2011 05:58 AM
themachinist
13
Jul 21, 2008 08:58 AM
hondamonkey
18
Mar 29, 2006 07:00 PM
sb
Aug 4, 2005 07:19 PM
