gsr swap in 96 hb
Hey everybody I have a gsr swap into a 96 honda civic cx hb. I got everything done except I need to hook up the charcoal/carbon canister sensor. Does anybody know how to do the exact pinout for the canister sensor? Thanks for your help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eknorcal »</TD></TR><TR><TD CLASS="quote">Hey everybody I have a gsr swap into a 96 honda civic cx hb. I got everything done except I need to hook up the charcoal/carbon canister sensor. Does anybody know how to do the exact pinout for the canister sensor? Thanks for your help.
its a 98 USDM b18c1. any idea?
</TD></TR></TABLE>its a 98 USDM b18c1. any idea?
I wish I could be of more help to you, but while you're waiting for an answer run an archived search for "pinouts" or something like that and see what happens.
Dunno if you'll find exactly what you're looking for, but who knows...you may. In the meantime i'll run a search or two and see if I can find anything useful although you know what you're looking for a bit better than I do.
EDIT: Searched pinouts and got 239 results but didnt feel like going through them all. Then I searched "sensor pinouts" and only got 8 results but I dont think any of them would have helped you.
Good luck man.
Good luck man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Shot 50 Cent »</TD></TR><TR><TD CLASS="quote">I wish I could be of more help to you, but while you're waiting for an answer run an archived search for "pinouts" or something like that and see what happens.
Good luck man.</TD></TR></TABLE>
thanks a lot man. i actually have the ecu pinout schematics online. got it on http://www.ff-squad.com/technet/wiring.obd2a.htm
there's 2 possible pinouts. either slot A-15 or A20.
A-15 says it's the "PCS- evap purge control solenoid valve."
A-29 is the "VSV- evap control canister vent shut valve."
i'm just not quite sure which slot i hook up the sensor to. u seem to have more knowledge than me in this so take a pick. haha
Modified by eknorcal at 2:42 PM 12/10/2006
oh i forgot to mention that it's a 98 gsr swap into my 96 cx hb. im running everything stock so it has the stock obd2a p72. hope this clears things up a little more
</TD></TR></TABLE>oh i forgot to mention that it's a 98 gsr swap into my 96 cx hb. im running everything stock so it has the stock obd2a p72. hope this clears things up a little more
up
up
i guess no one is knowledgable in this area.
</TD></TR></TABLE>i guess no one is knowledgable in this area.
