HOW TO PRIME THE OIL PUMP ON B18C1 FOR A FRESH REBUILD.
We just put my engine back togheter after a blown head gasket and so i put new piston rings and other goodies.
Now im trying to figure out if there is a way to prime my oil pump to get all the juices flowing ahead of time so there is no abnormal wear..
Also what procedures should i do to set timing and adjusting my CAM gears.
Thanks GUYS..
Thanks GUYS..
its not a SBC you cant really prime the pump... actually you can pull the ECU fuse and crank it like 10times then throw the fuse back in and start it up...
i have never done anything like that before. i just cover all the internal parts in oil and assembly lube so it has lubrication during that first second the oil cant get there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFsSuck »</TD></TR><TR><TD CLASS="quote">its not a SBC you cant really prime the pump... actually you can pull the ECU fuse and crank it like 10times then throw the fuse back in and start it up...
i have never done anything like that before. i just cover all the internal parts in oil and assembly lube so it has lubrication during that first second the oil cant get there...</TD></TR></TABLE>
read the bambam lsvtec thread. he primes the pump in there i believe. thats better than me tryign to explain it. theres pics.
Remove the allen plug on the oil pump 9behind the alternator) and use a skurt can to fill it with oil. Replace the plug and crank with out spark plugs and fuel pump. Should take 20 seconds to get pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">Remove the allen plug on the oil pump 9behind the alternator) and use a skurt can to fill it with oil. Replace the plug and crank with out spark plugs and fuel pump. Should take 20 seconds to get pressure.</TD></TR></TABLE>
is a skurt can one of those old school devices with with the little metal tube and the trigger?
You can use a cheap 1 gal vegetation sprayer. Remove the oil switch and isntall a pipe fitting, install some hose between the fitting and the sprayer (remove sprayer jet first), fill a clean sprayer with a few qts of oil, pump and hold. It takes 5-10 minutes but you will fill the engine and pump oil to all the bearings. It's a temporary accusump.
Chargerhemi06
Dec 4, 2014 05:43 PM
Meanmagic94EX
14
Apr 15, 2012 12:53 AM
