***VOLVO 850R, T5R, all R series Theard***
Old Dec 10, 2006 | 12:04 PM
Biturbo's Avatar
Default ***VOLVO 850R, T5R, all R series Theard***
All VOLVO R series theard
______________________
VIDEO must see! http://video.google.com/videop...q=850
850R 250hp stock
S70 250hp stock
S60R (V70RII) 300HP stock
Modified by Biturbo at 8:10 AM 12/11/2006
Old Dec 10, 2006 | 12:34 PM
Boosted Chemist's Avatar
Default Re: ***VOLVO 850R, T5R, all R series Theard*** (Biturbo)
That **** is gay looking
Old Dec 10, 2006 | 12:37 PM
nathanong87's Avatar
evolve s40
Old Dec 10, 2006 | 12:39 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: ***VOLVO 850R, T5R, all R series Theard*** (nathanong87)
^^^^ more!?
Old Dec 10, 2006 | 12:42 PM
Default Re: ***VOLVO 850R, T5R, all R series Theard*** (spock_rocker)
Now that volvo is hot, any specs on it?
Old Dec 10, 2006 | 12:45 PM
Default Re: ***VOLVO 850R, T5R, all R series Theard*** (Boosted Chemist)
was made for sema
Stunning Exterior Styling
From 30 feet away it's clear that the Evolve S40, while based on a production version of the popular Volvo S40 sport sedan, is no "normal" Volvo. Praised by the automotive media for its good looks, Volvo S40's design cues are taken to the extreme with the Evolve S40. What's most noticeable is the aggressively styled custom-built body and trim pieces. Up front is the Evolve designed front bumper with an ultra-deep front spoiler that houses Evolve Cars' signature mesh grille inlays. Functional twin air inlet scoops molded into the front fenders direct cool air over the turbocharger and into the engine compartment for improved performance and better engine cooling.
Lower side sills, rear valance, trunk spoiler and taillight trim add to the Evolve S40's aggressive appearance. The fuel door has been saved and the filler is relocated out of sight. Perhaps what lends most to the Evolve S40's stance is the high-performance wheel and tire package. As with all true performance cars, the Evolve S40 rides on staggered shoes. The lightweight HRE "C21"alloy wheels are 8.5-inches wide in front and a full 11.0-inches wide at the rear. Diameters front and rear are 19.0 inches. The wheels are wrapped in low profile Pirelli PZero "Rosso" tires that are 255/30ZR-19 up front and 305/25ZR-19 around back.
Other exterior modifications include a custom made 3.5-inch dual exhaust system, darkened tail lamps and a body color moon roof.
Fire Breathing Engine
The two small openings on the Evolve S40's fenders belie its performance potential. Used to direct air in and around the engine compartment, they are needed to keep things cool beneath the car's sculpted hood. And they are truly needed. Residing front and center in the engine bay is a massive intercooled turbocharger. Thick veins of plumbing run across the inline 5-cylinder engine and a strut tower brace helps stabilize the chassis of the Evolve S40 for up to 550 horsepower of body twisting power.
Obviously with an engine capable of producing this much power, heat is an issue that needs to be dealt with accordingly. Heat resistant silicone hoses and heat protection material keep the Evolve S40's fluids from boiling and the paint from peeling off the hood.
State of the Art Suspension & Braking System
Bringing 550 snorting horses to a stop in short order is the Evolve S40's high-performance braking system. Up front are monstrous 380mm two-piece rotors with eight-piston liquid cooled AP Racing calipers. At the rear are 362mm two-piece rotors with six-piston AP Racing calipers. Gracing the massive rotors is a special slotting pattern using the signature Evolve “E” to maximize braking performance. Keeping all of this under supreme control is Volvo's anti-lock braking system with electronic brake force distribution.
When Evolve decided how much tire contact patch they needed to handle the power and deliver the cornering and braking performance desired, it quickly became clear that an extraordinary suspension was needed. To accommodate, Evolve’s Chief Engineer, Mano Agulian, created a Formula One style pushrod rear suspension, bringing the strut/spring assembly inboard into the vehicle’s trunk and created new wheel wells around the aggressive tires. Up front, a custom Evolve adjustable coil-over suspension provides precision handling and a nearly flat cornering stance. Large Evolve anti-roll bars and fully adjustable Koni struts and Eibach springs give the driver ultimate control and adjustability for any road surface. Volvo's Dynamic Stability Traction Control (DSTC) system is also on hand to help keep the car under control during extreme maneuvers.
Old Dec 10, 2006 | 12:50 PM
Scotty Dosent Know's Avatar
My R wagon, old *** pics everybodys proably seen but ohh well lol
Old Dec 10, 2006 | 12:52 PM
aaronISthrowed's Avatar
Default Re: (ecko1980)
^ More pix of the feme in the reflection.
Old Dec 10, 2006 | 01:08 PM
Djole_V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 &raquo;</TD></TR><TR><TD CLASS="quote">evolve s40
That is hot
Old Dec 10, 2006 | 01:12 PM
A_P_1's Avatar
on that S40
Old Dec 10, 2006 | 01:15 PM
ATS*Mark's Avatar
OG triple OG
Default Re: ***VOLVO 850R, T5R, all R series Theard*** (A_P_1)
i will be getting an s60 R they are so gorgous.
Old Dec 10, 2006 | 01:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: ***VOLVO 850R, T5R, all R series Theard*** (ATS*A$$HOLE)
evolve s60r
Old Dec 10, 2006 | 01:19 PM
Moedizzle's Avatar
The suspension on that S40 is insane. Looks like a racecars suspension. Evolve builds some sick *** cars
PSU's Avatar
PSU
formerly DxHatchback
Default Re: (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">^ More pix of the feme in the reflection.</TD></TR></TABLE>
you beat me to it, haha!
Old Dec 10, 2006 | 01:35 PM
sixfiveoh's Avatar
Sweet Title
Old Dec 10, 2006 | 01:45 PM
SteveoBA8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">That **** is gay looking </TD></TR></TABLE>
YOU are gay looking.
Old Dec 10, 2006 | 01:54 PM
Newkdog's Avatar
I miss Andrea.
There are two silver S60 R's on base. I am going to try and take a picture of one.
Old Dec 10, 2006 | 02:14 PM
teamsoy1320's Avatar
i wish i couls afford a s60r...that blue leather is teh hottness
Old Dec 10, 2006 | 02:42 PM
NrG's Avatar
NrG
Default Re: (teamsoy1320)
I remember seeing the evolve s40 at the LA auto show two years ago.
Very well put together car
Old Dec 10, 2006 | 03:02 PM
__oversea's Avatar
Default Re: (NrG)
damn.
what is the different between s40r and s60r?
Old Dec 10, 2006 | 03:03 PM
Default Re: (ZeroTalent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeroTalent &raquo;</TD></TR><TR><TD CLASS="quote">damn.
what is the different between s40r and s60r?</TD></TR></TABLE>
whut's the difference between an eg and an ek?
Old Dec 10, 2006 | 03:08 PM
TeH PLAYA's Avatar
Default Re:
diggin that evolve s40
Old Dec 10, 2006 | 03:11 PM
waddy41's Avatar
i like my 240's
Old Dec 10, 2006 | 03:37 PM
peacexisxfree's Avatar
Default Re: (waddy41)
Don't have an R, but thought I'd post my ride. Not many Volvo owners here, so I wanted to keep this thread alive
Old Dec 10, 2006 | 03:53 PM
EG2Driver's Avatar
you close minded piece of ****
Volvos
