Fuel Leak?
Old Dec 10, 2006 | 11:48 AM
EJ8 GSR-T's Avatar
Default Fuel Leak?
I just built my motor and i am thinking i may have a fuel pressure leak. I have a gauge on the fuel rail and when i shut off the car it goes from 50 or so psi then to 45 and 40 and from there it drops pretty rapidly. I understand it can be one of three things, either the injectors leak the FPR leaks or the pump leaks. I dont think the fuel pump is letting fuel go back so its down to the FPR and the injectors. How can i tell, because i dont have any special equipment.
Old Dec 10, 2006 | 01:53 PM
96-EJ6 B18C's Avatar
Default Re: Fuel Leak? (EJ8 GSR-T)
It's normal for the pressure to bleed down over time.
What pressure regulator are you running?
Old Dec 10, 2006 | 06:13 PM
EJ8 GSR-T's Avatar
Default Re: Fuel Leak? (96-EJ6 B18C)
aem...i dunno because on my s2k it goes down but not nearly so fast
Old Dec 10, 2006 | 06:16 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">aem...i dunno because on my s2k it goes down but not nearly so fast</TD></TR></TABLE>
Depends on the regulator.
It's normal.
Old Dec 10, 2006 | 07:26 PM
Brick Top's Avatar
if it would be leaking pressure, it would probably be leaking gas too. being thats what gives the pressure.
4drDA
Nov 11, 2004 12:58 AM
ITRfaithful
May 13, 2004 11:47 AM
specie
Nov 6, 2003 10:28 AM
Islander
May 19, 2003 11:08 AM
