question about oil (about viscosity)
Old May 11, 2002 | 03:42 AM
far's Avatar
far
Default question about oil (about viscosity)
i was wondering since i live in socal and the temp doesnt really get that low, what weight oil should i use. right now i use 5-30 mobil 1 synth. what weight oil could i run safely? thanks in advance
Old May 11, 2002 | 01:59 PM
vteg's Avatar
New User
Default Re: question about oil (98tegsr)
I have used 0-30 synthetic for about 30k miles. You can get away with using various weights. Just remember that as the cold weight(5) increases it will take longer to get oil to the top of your engine on startup. As the hot weight increases you will get pumping losses when hot.
Old May 11, 2002 | 07:10 PM
far's Avatar
far
Default Re: question about oil (vteg)
are there any real reasons to not use 5-30W and use something else? i mean will i see a diffrence in anything? and is colder a lower number or higher? thanks
Old May 11, 2002 | 07:31 PM
MattG's Avatar
New User
5-30 is fine. The 5 is for colder temps. The oil is thinner. Once it warms up it goes to 30. If you were in the artic or possibly someplace really cold you could consider 0-30.
There are some people think oils will add HP but in reality unless you run a high HP motor you will probably not notice any gains especially since you use Mobil1
Old May 11, 2002 | 08:18 PM
far's Avatar
far
Default Re: question about oil (MattG)
alright. thanks alot for your help
Old May 12, 2002 | 12:41 AM
Goy091's Avatar
hmm, i live in CA too, i just use 10w-30 year round
islnder102
Oct 12, 2006 06:45 AM
The Weather Man
Sep 21, 2005 06:17 AM
lucidvtec
Jun 29, 2005 09:24 PM
LOwrestling2001
11
Aug 26, 2002 09:00 PM
1hotintegra
Jul 10, 2002 03:39 PM
