ls/vtec build question......
Old Dec 10, 2006 | 08:17 AM
FutureCivic's Avatar
Default ls/vtec build question......
Hey guys,
I am about to purchase a LS block from a buddy, it comes with the LS crank and rods. I have JDM itr pistons P73-00 that im gonna install along with a SiR2 B16 head and full itr valvetrain including cams, considering gettin a ctr intake cam.
I also have a Spoon ECU (genuine **** not a chip!) It came with a friend's EG6 from japan. Was wondering if i can run it on this along with the AFC Neo until i get my hondata? All this is goin into a crx....
Thanks
Old Dec 10, 2006 | 01:56 PM
CustomX113's Avatar
Banned
you should be fine just keep the revs low, my friend ran a stock p28 for a few hundred miles on a 12.2:1 ls vtec til he was able to get it tuned, we just cranked up the fuel pressure, he also never revved it over 5k
Old Dec 10, 2006 | 02:52 PM
Forrest Gump 9's Avatar
Default Re: (95dxb18c1)
Might as well get a set of Eagle rods in there while you at it.
Old Dec 10, 2006 | 02:55 PM
CustomX113's Avatar
Banned
Default Re: (Turbo9Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">Might as well get a set of Eagle rods in there while you at it.</TD></TR></TABLE>
very true or atleast a set of probes because im sure you plan on revving it past 7200
Old Dec 10, 2006 | 03:04 PM
Brick Top's Avatar
aftermarket rods won't fit oem pistons. just use arp rod bolts.
Old Dec 10, 2006 | 03:12 PM
CustomX113's Avatar
Banned
Default Re: (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">
aftermarket rods won't fit oem pistons. just use arp rod bolts.</TD></TR></TABLE>
oop very true, i forgot about that, you would have to get them machined
Old Dec 11, 2006 | 12:55 PM
Yea thanks for the reply guys, i was considering gettin eagle rods and wiseco pistons 11.5:1 or so
But money constraints wont allow me to do this right now. Planning on revving to 8200 but a redline of 8500 just to be safe. I might change the itr pistons to sir2 b16's.
4DRmafia
Nov 2, 2006 09:20 AM
imskatencrzy
Sep 30, 2006 02:56 PM
EGcivicvtec
21
Jan 11, 2006 05:29 PM
ReV LiMiT
May 1, 2004 02:34 PM
jaydmcrx
13
Jan 4, 2004 04:24 PM
