b20 vtec with b16 head... what timing belt to use?
alright im having trouble im trying to find out what timing belt to use.
b20 one is to big.
my ls vtec old one is to big.
I bought a integra gsr one and its to small
which one should I be using.
Thanks
b20 one is to big.
Thanks
Are you sure the GSR is too small? And what water pump do you have on there? Is it a 19 or 22 tooth?
When doing a B20VTEC you should also get a 22T VTEC water pump, and a B18C timing belt, like the GSR which you have. You are sure the GSR belt you have is for a B18C and not the old gsr that had a B17?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations »</TD></TR><TR><TD CLASS="quote">LS/B20 water pump = LS/B20 timing belt
GSR/B16 water pump = GSR timing belt</TD></TR></TABLE>
Like it says, if you have a B20 water pump, then by a LS Integra belt (easier for the auto parts guy to understand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laughing Man »</TD></TR><TR><TD CLASS="quote">I used a B16 timing belt on my b20/vtec with no problems</TD></TR></TABLE>
i dont think that right, the belt would be way too short
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning »</TD></TR><TR><TD CLASS="quote">
i dont think that right, the belt would be way too short</TD></TR></TABLE>
I had no problem with mine. (shrugs)
i dont think this can be done. deck height on b20 block is taller than b16 block. u sure u didnt use a gsr?
I had no problem with mine. (shrugs)</TD></TR></TABLE>
you musta had a gsr belt to begin with lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laughing Man »</TD></TR><TR><TD CLASS="quote">Im sure, the timing belt was for a B16A2 from the honda dealership... </TD></TR></TABLE>
No way that would fit on a B18/B20 block, there is a 8.9mm deck height difference between those and the B16 so the belt will have to be 17.8mm longer, there's not enough adjustability on the tensioner to make that work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut »</TD></TR><TR><TD CLASS="quote">What ever block you using, use that timing belt. So in your case, b20/b18 timing belt.</TD></TR></TABLE>
the water pump also plays a role in which belt to use. as was previously stated numerous times in this thread.
ok i dono what water pump is on lol i just took off my b16 head and put it on a b20 block no changing anything.
i have a gsr belt supposidly but the guy said it was 1.6l which a gsr is 1.8l did i get the wrong belt.
If you are using the stock B20 water pump YOU NEED A B20/LS BELT, did you read your own post? There was a 1.7 GSR in 92-93 that used the same belt as the B16's. Once again YOU NEED A B20 BELT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kirk@SyndromeAuto »</TD></TR><TR><TD CLASS="quote">ok i dono what water pump is on lol i just took off my b16 head and put it on a b20 block no changing anything.
i have a gsr belt supposidly but the guy said it was 1.6l which a gsr is 1.8l did i get the wrong belt. </TD></TR></TABLE>
simple. count the number of teeth on the pump. 19 = non vtec = non vtec belt. 22 = vtec = vtec b18c belt
Yes. But you would be smart to spend $100, and buy a VTEC water pump. Don't by a chinese knock off either. OEM honda, PERIOD.
The B20/LS pump has less teeth (smaller pulley) and will spin faster, which isn't a good thing.
Then buy a GSR belt.
