What seats that fit an EF
I need to know if 94 civic seats from a DX coupe fit in a 1988 civic hatch dx.
Thansk for your help in this matter I did a search and got mixed result.Do they fit Thats all I need to know.
If you're asking if they're a direct fit, they're not!!! Holes/bolts will not line up...maybe 1 in 4...BUT YOU CAN MAKE EM FIT...by either drilling new holes or making your own bracket or running another search cuz this topic has been discussed before...maybe not in exact words but you got the general idea.
I read the one abot switching out the pans and such.But i cant use my rails due to the driverside seat is broke near the brackets by the prevouis owner.Guess Ill just have to drill new holes or somthing in thata matter.
most seat pans are rivetted to the seats and quite difficult to remove...and once you finally get em removed, of course they're tough to reattach.
Well I have been a member since 02 I just don’t post much on here. I read more then post. I was just lazy that’s why I posted it lol. I have one of them in to replace my old driver side seat that has a left rail broken. You only can get one hole to line up next to the shifter that’s it. The one closes to the door doesn’t work it is slightly higher on the hump part. So if you are desperate to make it work. You would have to make a new hole for it. The left rear one is flat on the factory seat 88-91. This won't work either because the 92-95 is not flat it’s turned down like the front ones.
Same goes for the right rear.Im sure everyone that commented on this knowed this. I for one didn’t but now I do so I share this one to all of you.
extensioncordy
Jul 30, 2006 02:35 PM
Undrgrndhaqer
Jul 3, 2004 08:47 AM
