k24a4 into EG swap... need some kinda info
Old Dec 9, 2006 | 09:22 PM
xjreazyx's Avatar
Default k24a4 into EG swap... need some kinda info
So i picked up my k24 and my tranny... if anyone has done this swap or heard of it done, i need some info on possible snags i might hit
Old Dec 9, 2006 | 11:46 PM
xjreazyx's Avatar
Default Re: k24a4 into EG swap... need some kinda info (xjreazyx)
ok, so i figure i should be a little more specific... if im pairing a type s tranny to a k24, would i use the accord flywheel and clutch, or the rsx?
Old Dec 10, 2006 | 12:21 PM
ekb16's Avatar
i might wanna try k20a.org for more info
Old Dec 11, 2006 | 10:48 AM
EATIN UP UR BSERIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xjreazyx &raquo;</TD></TR><TR><TD CLASS="quote">ok, so i figure i should be a little more specific... if im pairing a type s tranny to a k24, would i use the accord flywheel and clutch, or the rsx?</TD></TR></TABLE>
i would us rsx flywheel and clutch..why would you swap low comp accord block i would get a tsx or type s block or some pistons and rods...i personally dont think putting a A4 is worth it unless your boosting your gonna spend at least 3000 just to get the motor to run in the car...
Old Dec 11, 2006 | 11:26 AM
vtecspeed1320's Avatar
Shooting Star
Default Re: k24a4 into EG swap... need some kinda info (EATIN UP UR BSERIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EATIN UP UR BSERIES &raquo;</TD></TR><TR><TD CLASS="quote">i would us rsx flywheel and clutch..why would you swap low comp accord block i would get a tsx or type s block or some pistons and rods...i personally dont think putting a A4 is worth it unless your boosting your gonna spend at least 3000 just to get the motor to run in the car...</TD></TR></TABLE> I would have to agree to an extent...the a4 block is pretty much a dead motor if you ask me, although its still a "k" I guess. but for the money he probably paid for this motor hes not in the market for a k20a2, k24a2. You will make ok power with this motor and have tq. but upgrades will come hard, since the k20a2 head does not allow the valve to piston clearance needed for the vtc. so you will then later on have to buy rods and pistons and have down time.
Old Dec 11, 2006 | 05:45 PM
v4lu3s's Avatar
RTFM
or make 450+ hp like another houston area guy did boosting the accord engine.
Old Dec 11, 2006 | 11:29 PM
xjreazyx's Avatar
Default Re: k24a4 into EG swap... need some kinda info (vtecspeed1320)
see, i had heard that there was a bit of inginuity needed to work that type s head onto the a4 block, so i wasnt sure if that would be the way to go.
here's a question i have been trying to figure out... the b18 i have in there now is coming out, and the tranny is mounted on the opposite side of the block as the k24. Will I basically have to relocate everything to the opposite side of the engine well? i have an EG, so the engine well isnt exactly small... if anything will get in the way, it looks like it would be the battery
Old Dec 11, 2006 | 11:34 PM
xjreazyx's Avatar
even if it costs 3000 to get the engine running the vehicle, that leaves me a good couple thousand in building the engine up that I would have spent on just the swap had I gone with the type s or tsx.
And believe me, the lower comp has already been BEGGING me to boost lol
Davesgarage831
Northern California (Sales)
Apr 20, 2008 09:24 PM
ant9902
Jan 28, 2008 05:17 PM
Derfology
11
Sep 25, 2005 09:54 AM
eg_nezay
Jun 20, 2004 03:53 PM
