overheating
Old Dec 9, 2006 | 08:04 PM
JdM_RACeR07's Avatar
Default overheating
what are the other causes of overheating......i changed my thermo and the water pump works as well....what else is there???
Old Dec 9, 2006 | 08:06 PM
.Manny.'s Avatar
Touching My Member
Default Re: overheating (JdM_RACeR07)
if there is air in the system, you will have problems, bleed the system
Old Dec 9, 2006 | 08:14 PM
Default Re: overheating (90_EF_Si)
okay and ive heard theres a bleeding screw, you just unscrew until a steady flow comes out...do you know where that is??? its a dohc zc if that helps
Old Dec 9, 2006 | 08:20 PM
EG8R's Avatar
On a single cam it's at the housing that the upper rad hose connects to at the cylinder head
Old Dec 9, 2006 | 08:24 PM
Default Re: overheating (skelly ed666)
okay and i have a dual cam does anybody know where it is on that???
Old Dec 9, 2006 | 08:43 PM
AndrePerras's Avatar
just run it with the rad cap off at idle for like 15mins idle
Old Dec 10, 2006 | 06:49 PM
looxs's Avatar
Default Re: overheating (AndrePerras)
also make sure u didnt get a bad thermostat because this jus happened to me.. jus because its new doesnt mean it works
Old Dec 10, 2006 | 06:51 PM
4doorcivic16's Avatar
should be in the same spot as the single cam
b18egtheehatch
Feb 26, 2015 09:59 PM
cookiemonsta08
Jun 2, 2011 08:09 AM
sirej809
15
Dec 30, 2009 07:38 PM
onefine99
Apr 27, 2008 05:03 PM
loosestring
Nov 13, 2005 09:53 AM
