vTec head OR vTec motor? SOHC
Old Dec 9, 2006 | 05:01 PM
roterx7's Avatar
Default vTec head OR vTec motor? SOHC
im not sure if i should just get a vtec head for my sohc zc or just get a z6 motor. what do you guys think? opinons and facts. its in a 89 si crx btw
thanks
Old Dec 9, 2006 | 05:22 PM
HatchMo's Avatar
why is "t" in vtec caps...
Old Dec 9, 2006 | 05:34 PM
roterx7's Avatar
Default Re: (HatchMo)
y is your name hatchmo, y is the m upper case? y are u asking dumb questions? y are u responding if you dunt know anything related to the topic? dumb questions get dumb answers...thats why
Old Dec 9, 2006 | 05:37 PM
justseeingifitistaken's Avatar
Default Re: (roterx7)
alot of peeps will say keep the a6 bottom end and z6 head! i would rather the newer engine altogether. preference mainly as to what you are going to use it for.
Old Dec 9, 2006 | 08:35 PM
HatchMo's Avatar
good comeback tj hooker
Old Dec 9, 2006 | 08:41 PM
Steri's Avatar
Default Re: vTec head OR vTec motor? SOHC (roterx7)
I would get the z6. Newer is always nice less mileage!
Old Dec 10, 2006 | 12:33 PM
roterx7's Avatar
im jus going to use it for daily driving. its a zc with low milage not too much, it came form attarco. also aside from the longblock or head question, z6 or y8? or theres no difference on the motor/head
thanks
Old Dec 10, 2006 | 04:26 PM
0bd1_Kanobe's Avatar
I belive that they are the same exept for minor changes like the IM and TB and valvecover
Old Dec 10, 2006 | 04:36 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (0bd1_Kanobe)
depends on the mileage of the head and your block, if you rebuild both it sounds like a good idea. Otherwise I would just do the whole motor swap.
Old Dec 10, 2006 | 06:03 PM
roterx7's Avatar
the head is roughly 100k and the block i would say 80k- 90k
Old Dec 22, 2006 | 03:33 PM
roterx7's Avatar
i was reading sum websites about the head swap, and i was wondering what ecu should i use? should i stick to my crx si one (pm6)? or is there a better one i can use?
Old Dec 22, 2006 | 03:58 PM
24TEN's Avatar
PHANTOM MENACE
PM6 isn't designed for VTEC. So unless you wanna run without the use of VTEC, you'll either have to have a manual VTEC switch (not recommended, unless you have the ECU reprogrammed..in which case I'd still run the correct ECU) or run a VTEC ECU.
Old Dec 22, 2006 | 04:14 PM
PACT man's Avatar
Default Re: (24TEN)
The difference between the z6 and the y8 vtec engines are that the newer y8's have a knock sensor, while the z6 is different in that it didn't use a knock sensor but did use a crank position sensor. And there within lie the differences of the ECU's used between the 2 engines... and yea of course the obvious IM and TB.
Old Dec 22, 2006 | 06:39 PM
user 98292739's Avatar
Default Re: (PACT man)
the timing on the Y8 is different too.
z6 had better timing
the y8 also has a weaker oil pump spring.
Old Dec 22, 2006 | 06:53 PM
ekslax's Avatar
71.172.180.139
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roterx7 &raquo;</TD></TR><TR><TD CLASS="quote">y is your name hatchmo, y is the m upper case? y are u asking dumb questions? y are u responding if you dunt know anything related to the topic? dumb questions get dumb answers...thats why</TD></TR></TABLE>
lol, he destroyed him with that comeback, the guy didnt even respond after that one.
Old Dec 23, 2006 | 12:26 AM
HatchMo's Avatar
yeah he got me!
Old Dec 24, 2006 | 09:29 AM
roterx7's Avatar
the ecu is p28 right? thats just from on top of my head so im not sure if im right or not. im usung a z6 head
Old Dec 24, 2006 | 11:44 AM
schardbody's Avatar
depends on what you plan to do afterwards, if you wanna rock it N/A stick with the a6 bottom end, the compression will be ALOT nicer with the headswap compared to just a motor swap. IMO, the a6 with z6 or y8 head is a better N/A setup, and im partial to the die-ing a6's.
Old Dec 24, 2006 | 12:32 PM
24TEN's Avatar
PHANTOM MENACE
Yeah, the P28 is the corresponding ECU for the D16Z6.
Old Dec 24, 2006 | 05:34 PM
SOHCness Monster's Avatar
i have the y8 head and the sohc zc bottom end if i were you double check the piston rings in the block and the valve seals in the head thats what went out on my **** first and both were low miles
Old Dec 24, 2006 | 05:47 PM
killahsi2003's Avatar
i say vtec head
Old Dec 24, 2006 | 08:44 PM
roterx7's Avatar
any other things i should know cuz i only have a weedend at the most to do this head swap, got work during the week and dont really want to take up my whole 2 day weekend with **** cuz its my DD
thanks
Honda Daze
Feb 1, 2019 05:00 PM
Slavik89
Jun 12, 2013 11:48 AM
i_VTEC
Aug 22, 2007 01:09 PM
EsCo_EsCo
Jun 4, 2004 05:23 AM
