Will spoon calipers fit a DA
Old Dec 9, 2006 | 04:53 PM
CRX_Fenatic's Avatar
Default Will spoon calipers fit a DA
Exactly what the post says
Old Dec 9, 2006 | 08:39 PM
PrinceAli132's Avatar
Default Re: Will spoon calipers fit a DA (CRX_Fenatic)
Aren't they supposedly made for the Type R?
If so then you'll need to do the Type R brake conversion. I am not sure exatly what is all needed. But you'll need the brackets and rotors for sure.
Ali
Old Dec 12, 2006 | 06:40 PM
Nova_Dust's Avatar
Check the knuckle part number, see if it is the same as ITR, then get a 11" 4 bolt rotor, or just grab a 5 lug hub from junk yard, and get a ITR rotor if you don't want to source out a redrill 4 lug or an aftermarket one.
Lthlintgra09
May 21, 2009 07:34 PM
esponet
Apr 19, 2004 12:25 PM
mipawi
Jan 13, 2004 04:14 PM
Ekizzle
Sep 24, 2003 12:41 PM
shinchan
Jan 15, 2003 03:34 PM
