96 obdII h22 swap into 95 obdI accord
Hey guys, I'm not a prelude owner, but I figured the prelude forum would be a good place to ask this question. I just picked up a wrecked 96 prelude with a h22 swap. I drive a 95 accord which you know is obdI. My question is, other than the wiring for vtec, what all will need to be done to get this motor to run correctly and not throw any cel's in my obdI car. I want to be able to pass emmisions and everything work correctly. I'll have to pick up an obdi prelude ecu i assume. Will I have to change distrubutors and Tb's or anything? I'm probably going to use an accord Tb so I can keep my cruise control because the majority of my driving is Interstate. So what all will I need to do??? Thanks for your help in advance.
Modified by glamXXXrock at 2:41 PM 12/10/2006
you will need and obd1 h23-h22 distributor
p13 ecu
obd1 vtec prelude injectors i belive they are 345cc
and thats all i can remember right now.
p13 ecu
glamXXXrock
Dec 10, 2006 03:08 PM
B18PoweredCivic
May 3, 2003 10:43 PM
