new strkoer kit questions
i'm planning to buy a new stroker kit off of pocketrocketsracing.com for my 94 h22. here are some of the features for the Brian Crower stroker kit that i'm planning to buy.
1) ISO9001 Certified 4340 chromoly billet steel crankshaft (100mm stroke / 55mm main).
2) 4340 forged H beam steel connecting rods rated at max 650+HP.
3) Outstanding CP custom 2618 aluminum forged pistons made to order, incorporating 9310 nickel carbon steel alloy wrist pins, Ductile iron plasma top rings, tapered second ring, low tension oil rings. Some bore sizes are in stock, check with us for availability. Giving you the choice of the exact bore size and compression ratio requires a made to order Piston set,most require 3-5 weeks to manufacture.
4) Fully system balanced and ready to install.
the question is: what bore size and compression ratio should i select to give my all motor h22 its full potential power? any suggestions? thanks.
