how can i improve in my welds?
Old Dec 9, 2006 | 02:19 PM
drift2004's Avatar
Default how can i improve in my welds?
how can i improve in my welds? lincoln sp 125 plus wire,
Old Dec 9, 2006 | 02:42 PM
VRD^don's Avatar
Default Re: how can i improve in my welds? (drift2004)
clean the metal..was that with flux core wire?
Old Dec 9, 2006 | 03:01 PM
drift2004's Avatar
Default Re: how can i improve in my welds? (k_motor)
i dont know. how do i check?
Old Dec 9, 2006 | 03:22 PM
I Have an STD's Avatar
wrenchin'
looks like flux. do you use a shielding gas? those arent to bad man.
Old Dec 9, 2006 | 03:43 PM
drift2004's Avatar
Default Re: how can i improve in my welds? (I Have an STD)
what is a shielding gas?
Old Dec 9, 2006 | 05:05 PM
TIGboy's Avatar
Shielding gases are inert or semi-inert gases that are commonly used in several welding processes, most notably gas metal arc welding and gas tungsten arc welding. Their purpose is to protect the weld area from atmospheric gases, such as oxygen, nitrogen, carbon dioxide, and water vapor. Depending on the materials being welded, these gases can reduce the quality of the weld or make the welding process more difficult to use.
Old Dec 9, 2006 | 05:47 PM
drift2004's Avatar
Default Re: how can i improve in my welds? (TIGboy)
tig boy at least link it from your source, lol
Old Dec 9, 2006 | 07:11 PM
LordAphotic's Avatar
you need to work on consistency when your welding. look listen and feel for consistency. that usually means the well will be totally consistent. judging from your welds penetration that was your problem... but you would have an easier time welding a decent weld on an easier better machine like a gas mig welder not a flux core mig welder like the current one your using.
Old Dec 9, 2006 | 08:38 PM
TIGboy's Avatar
Default Re: (LordAphotic)
ok lol, wikipedia. but I didnt need that, just to lazy to type that mess.
Old Dec 9, 2006 | 11:02 PM
*Boostwerks*'s Avatar
I've definetly seen worse.
Old Dec 10, 2006 | 03:24 PM
dem0nk1d's Avatar
Default Re: (Boostwerks.com)
Well a buddy of mine used co2 as a Shielding GAS.
Old Dec 10, 2006 | 04:14 PM
standbackimapro's Avatar
Yah, Mig is usually 75percent argon, and 25 percent C02
and for tig i think they usually use 100% co2, or u can use 100% argon..
Old Dec 10, 2006 | 05:26 PM
drift2004's Avatar
Default Re: (standbackimapro)
i just need to grind it smooth and i have no leaks i checked with putting water inside
Old Dec 10, 2006 | 05:27 PM
drift2004's Avatar
drift2004's Avatar
Old Dec 11, 2006 | 01:56 PM
CBURKE's Avatar
Looks like mine on Flux
Old Dec 11, 2006 | 04:00 PM
HamiltonRex's Avatar
Default Re: (CBURKE)
****.. Just dont grind down TOO much.. Just kinda smooth out the high spots etc, dont try to make it flush.
If you think it looks ugly, just get some headerwrap and wrap that SOB
Old Dec 11, 2006 | 04:58 PM
sharkytm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">Yah, Mig is usually 75percent argon, and 25 percent C02
and for tig i think they usually use 100% co2, or u can use 100% argon..</TD></TR></TABLE>
argon only for most people. CO2 isn't used by many.
Old Dec 11, 2006 | 05:38 PM
9bells's Avatar
OG Fabricator
That's not the end of the world. It looks to me like you have too much wire stick-out. I know that crap wire spatters alot, but by the size I would say keep the nozzle closer to the work.
A good technique when heat brings excessive spatter is to bevel the tubing a little
with a grinder, and turn the heat down. You can try to turn it down quite a bit, and whip the puddle a bit. Keep the nozzle really close to the weld.
Shielding gas and mig wire will give better results next time. Not sure if you can with your welder, thought you might have the ability to hook-up a small gas cylinder.
Good luck.
Old Dec 11, 2006 | 05:43 PM
Fenrir51's Avatar
Default Re: (drift2004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 &raquo;</TD></TR><TR><TD CLASS="quote">i just need to grind it smooth and i have no leaks i checked with putting water inside
I really wouldnt bother to grind it down. You may lose the weld strength if you do.
Old Dec 11, 2006 | 06:01 PM
scartail's Avatar
Nice. It's got character. My downpipe looks similar. Not as many mitre cuts, though.
Old Dec 11, 2006 | 07:36 PM
sohc_turd's Avatar
Default Re: (scartail)
Its not gonna win any beauty contests, but it'll get the job done. Nice job on the DIY!
that-guy
Welding / Fabrication
12
Mar 23, 2011 09:48 AM
precisionsc54
11
Jan 26, 2010 08:06 AM
redsikiller
Apr 29, 2006 12:04 PM
lewdude
14
Jan 26, 2005 06:05 PM
spoonhatchblack
Jan 19, 2005 10:31 AM
