belt # or length for jackson sc on R
Old Dec 9, 2006 | 02:01 PM
Ztrtyper's Avatar
Default belt # or length for jackson sc on R
Anyone know the belt size offhand?
Old Dec 9, 2006 | 05:23 PM
94rs-turbo's Avatar
I have the # in my garage ill post it later
Old Dec 9, 2006 | 05:41 PM
MOVE OVER's Avatar
Default Re: (94rs-turbo)
NAPA part # 040250
9/16" x 25 - 3/4"
14mm x 655mm
I always keep a spare in the garage
Old Dec 9, 2006 | 05:45 PM
Comp97GSR's Avatar
Default Re: (ITR 1102)
Kevin is so helpful.
Old Dec 12, 2006 | 06:10 PM
Ztrtyper's Avatar
hell ya thanks guys
Old Dec 12, 2006 | 06:55 PM
exies's Avatar
Default Re: (Ztrtyper)
That is the size for the stock belt right?
Old Dec 13, 2006 | 07:06 AM
MOVE OVER's Avatar
Default Re: (exies)
Actually, you may have gotten me there....
I have the Motorvations 7 psi pulley
Thinking about it, if you have the stock pulley on, it would be a larger diameter pulley than the 7 psi pulley. So if anything, this belt, which I still think may be the original size, would work. You would just have to tighten it, and I'm pretty sure that there is enough room to tension it that much. (somebody check me on this)
The belt is cheap, I got mine for about $4 a peice at NAPA, so just go buy it. I am pretty sure it will work, and when it does, go get a spare
hedtrip
Jan 15, 2008 05:53 PM
K-Spec
Apr 30, 2005 04:19 PM
fastlude69
May 3, 2004 08:39 AM
LOwrestling2001
Jul 12, 2002 12:19 PM
