Out of fluid in the Clutch Cly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambodian »</TD></TR><TR><TD CLASS="quote">never mind, it works. had to pump it</TD></TR></TABLE>
you will still have bubble inside, it needs to be bleed out.
Go for a dash dive on the drivers side and look at where the Clutch pedal push rod goes thru the firewall; if you see leakage there it's time for a clutch master replacement.
One eyed mechanic says "it's low on fluid"
two eyed mechanic says "why is it low on fluid?"
hondapwr
19
Dec 21, 2007 06:16 PM
phantom_sol
13
Sep 9, 2003 03:22 PM
Qwikrex
Apr 20, 2003 03:27 PM
