Recommended Clutches For a 01 GSR
Old Dec 9, 2006 | 10:33 AM
IgnitionZ05's Avatar
Default Recommended Clutches For a 01 GSR
What clutches do u guys recommend? ACT, EXEDY, CLUTCHMASTERS??
Name some....
Old Dec 9, 2006 | 11:13 AM
PrinceAli132's Avatar
Default Re: Recommended Clutches For a 01 GSR (IgnitionZ05)
What do you have done to your car?
My car is basically stock and I am using a ACT HDSS with the streetlite flywheel and love it. It does have a stiffer pedal feel than OEM though.
Ali
Old Dec 9, 2006 | 12:25 PM
slow_ls's Avatar
I recommend clutch masters. I do not have one my self, but two of my friends do. One has the fx100 and other has fx200. I have driven both and they both grab much better compared to my stock clutch, but do not have **** worth of a pedal pressure increase just a little more on the fx200. They both race quite a bit and the clutches are holding up very well.
Old Dec 9, 2006 | 01:52 PM
davidluko's Avatar
Are you looking for just brand names, or a specific clutch? Personally I have an Exedy stage 1 on my basically-stock b18b1. It's only a tiny bit stiffer than stock, not hard at all. You won't even notice that it's aftermarket until you try an OEM clutch again and feel how soft the OEM really is. You're going to have to tell us what you have done to your car because an Exedy stage 1 obviously wouldn't work too well on a 500 whip drag car (just giving an example).
Old Dec 9, 2006 | 01:54 PM
yee SERIOUS's Avatar
i have an action clutch. it's the 2ks kit with the action 12lb flywheel. i used it for my turbo setup and i couldn't be more satsified. it's a bit stiffer than stock, but feels nearly the same. engagement is smooth and feels really good.
i got it shipped to me very quick from alchemist too. good service.
https://honda-tech.com/zerothread?id=1152082
here's some more info on the clutches:
http://www.garage-life.com/Action_Clutch.html
and rocket's write up on clutches:
http://www.garage-life.com/Clutch101_1.html
jwhezzy2003
Aug 28, 2008 08:46 AM
beanbag
Jan 9, 2008 04:09 PM
98GSRDC2
Jul 8, 2006 05:12 PM
johnqt3
Sep 13, 2005 08:20 PM
PoweredByPrelude
Mar 5, 2003 10:11 AM
