is it normal for aftermaket injectors to make clickin sounds? or is it another problem?
Old Dec 9, 2006 | 03:00 AM
JDM As It Gets's Avatar
Default is it normal for aftermaket injectors to make clickin sounds? or is it another problem?
motor is making wierd CLICKING sounds ever since i swapped it in. runnin 550 cc rc injectors and it makes an iradic (not normal / consisten ryhtm) clickin sound. like CLICK....CLICK....CLICK...
Modified by JDM As It Gets at 1:00 AM 12/19/2006
Old Dec 9, 2006 | 10:20 PM
dartdc97's Avatar
Default Re: is it normal for aftermaket injectors to make clickin sounds? or is it another problem? (JDM As
yes when you use bigger injectors you will here them clicking. they are hard at work
Old Dec 9, 2006 | 10:21 PM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM As It Gets &raquo;</TD></TR><TR><TD CLASS="quote">my JDM b18b LS motor is making wierd CLICKING sounds ever since i swapped it in. runnin 550 cc rc injectors and it makes an iradic (not normal / consisten ryhtm) clickin sound. like CLICK....CLICK....CLICK... </TD></TR></TABLE>
are you boosted??? why are you running 550 cc injectors?? Just curious
Old Dec 9, 2006 | 10:57 PM
B204door's Avatar
I'm having the same exact problem i just bought a 92 teg with a b20 it was my friends old car and ever since he put that motor in its been making a weird clicking noise. i made a forum bout this sum1 told me i need a valve adjustment. im not sure wat it is yet but i have an ls head he gave me and told me to put that on and see if the clicking is still there. if you figure out wat it is let me no and if i figure it out i'll let u no.
Old Dec 10, 2006 | 06:06 PM
Default Re: (B204door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">are you boosted??? why are you running 550 cc injectors?? Just curious</TD></TR></TABLE>
turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dartdc97 &raquo;</TD></TR><TR><TD CLASS="quote">yes when you use bigger injectors you will here them clicking. they are hard at work </TD></TR></TABLE>
ic. thanks 4 da info. peace of mind
b204door.. depend what kinda clikcin noise.. if its sequential /w ur thorrtle / revling and it gets like a tick and goes faster, u prolly need a valve adjustment. ur valve lashes are outta sync.
Zaraki
Sep 28, 2011 09:46 PM
trianglegreg
10
Jul 28, 2006 02:45 AM
KS-R
Aug 9, 2004 05:02 PM
SiRkid
Oct 21, 2003 09:53 AM
