engine shops in So Cal... are there only 3? *searched*
Old Dec 9, 2006 | 01:30 AM
black_bb1's Avatar
Default engine shops in So Cal... are there only 3? *searched*
I only know of Inlinefour, prostreet, and after some searching Laskey. They all look like and have the reputation of top notch race shops, but I'm just looking to fix my daily driven prelude its got an h22 and has spun a bearing (I think). I don't need to race prep it, just get it running again and on a college students budget I pulled the engine myself to try and cut out labor costs but thier still too expensive.
any recomendations for regular non-racing, or less expensive, shops?
I know good work doesn't come cheap but $1,700 is more than 2 months pay for me
Old Dec 9, 2006 | 01:50 AM
ExospeedAMcrx's Avatar
Default Re: engine shops in So Cal... are there only 3? *searched* (black_bb1)
To get good work done right, is not going to be cheap. We are in Glendale, CA if you need some engine work done. but not sure what type of build you are looking for? email me if you have any questions, if I cant do the work you want, i can help refer you ok.
Wil
Old Dec 9, 2006 | 03:08 AM
black_bb1's Avatar
Default Re: engine shops in So Cal... are there only 3? *searched* (exospeedAMcrx)
Thanks for the reply, I totally understand that good work warrants good pay, as far as what kind of "build" I'm looking for, I'm only looking for a rebuild I was totally fine with the power my engine made with just an intake and exhaust I want to keep my engine as stock/reliable as possible.
Old Dec 9, 2006 | 08:27 AM
to be honest with you, if you arent looking to pay for a rebuild(whcih may cost around $1000-1600.00, just for the block itself, no labor to remove and install and other parts such as timing belt and head gasket. the other option would be to just get another h22 stock low block to replace the one you have in there.
Old Dec 9, 2006 | 09:38 AM
k_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">to be honest with you, if you arent looking to pay for a rebuild(whcih may cost around $1000-1600.00, just for the block itself, no labor to remove and install and other parts such as timing belt and head gasket. the other option would be to just get another h22 stock low block to replace the one you have in there.</TD></TR></TABLE>
thats true...i rebuilt my block twice and it cost as much as buying a new motor with low miles...which is much more reliable...
Old Dec 9, 2006 | 11:26 AM
thegeorge613's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_bb1 &raquo;</TD></TR><TR><TD CLASS="quote">I only know of Inlinefour, prostreet, and after some searching Laskey. They all look like and have the reputation of top notch race shops, but I'm just looking to fix my daily driven prelude its got an h22 and has spun a bearing (I think). I don't need to race prep it, just get it running again and on a college students budget I pulled the engine myself to try and cut out labor costs but thier still too expensive.
I'll tell you one thing: never go to Inline Four for anything besides shopping there. Dunno about the other shops.
Old Dec 9, 2006 | 07:19 PM
ethereal2pt2's Avatar
Default Re: engine shops in So Cal... are there only 3? *searched* (thegeorge613)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">
thats true...i rebuilt my block twice and it cost as much as buying a new motor with low miles...which is much more reliable...</TD></TR></TABLE>
you mean a used motor w/ low miles? the problem with that is you wont know the full history of the motor and what kind of life it's had. a rebuild done right would be better since you know what kind of history it's had and if the shop is reputable then they should have gone the full 9 to make your motor running like new. i know a place here in kent, wa that does rebuilds and they offer 8 yr / 80,000 mile warranty on their work. err here i'll just paste what they do:
" Most companies use chemicals to clean engines before the rebuilding process. This leaves particles that can later dislodge and damage your engine. At U.S. Engines, we bake the engine for 12 hours at 800 degrees, leaving nothing to chance.
Once the engine is clean, we bore each cylinder to the next size larger, increasing capacity and power. Next we replace bearings, pistons, rings and plugs and straighten the crankshaft and rods. Then your engine is rinsed clean with hot anti-rust formula for 15 minutes.
Finally, we test each engine to ensure that when you put it back in your car, it will give you years of trouble-free service. With our 8 year – 80,000-mile, no nonsense warranty, you can be confident that our company stands behind our work. "
i need to rebuild my motor and im going to take it there soon. it's 1400 for nonvtec, mine has vtec so it's 2100. i'd do that. does even honda themselves offer 8 yr / 80k miles on their warranties?
oh and that's 5 years of labor for free.
Old Dec 10, 2006 | 09:28 AM
Default Re: engine shops in So Cal... are there only 3? *searched* (_BB6)
To give you an idea of what its going to cost for a rebuild with labor, roughly ok.
$1600 for a full rebuild
$300 for assorted parts, timing belt, head gasket, other gaskets, and new water pump.
Remove and replace engine labor, $800.00
So about $2700 if you are going to rebuild your engine and the labor and parts involved.
IF you find a good h22 used core, you're lookint at:
$500? for the block
$300 for assorted parts, etc.
$800 labor
So thats about $1600 or so.
Those are your options.
JarvisW
Texas -OK -LA (Sales)
May 15, 2009 01:19 PM
black_bb1
Dec 11, 2006 05:38 PM
tpdc2
Sep 21, 2006 12:19 PM
ludesleep
Sep 19, 2005 09:31 PM
SJR
16
Aug 28, 2003 12:40 PM
