Which Fuel pump is needed?
Old Dec 9, 2006 | 12:58 AM
JFG Kevin's Avatar
Default Which Fuel pump is needed?
I'm building up a LS/VTEC with 84.5mm cp 11.5 compression using a gsr p&p head on stg 2 cams. I was shopping for a fuel pump and there seems to be a few to select from but i dont know what i might need for this motor. There is a option of 190 and 255 and a 255 hp fuel pump. Which one is recommend?
Old Dec 9, 2006 | 05:21 AM
JDM94EG28's Avatar
Default Re: Which Fuel pump is needed? (JFG Kevin)
255
Old Dec 9, 2006 | 11:31 AM
Del Soouulll's Avatar
Default Re: Which Fuel pump is needed? (JDM94EG28)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM94EG28 &raquo;</TD></TR><TR><TD CLASS="quote">255</TD></TR></TABLE>
Old Dec 9, 2006 | 01:48 PM
00Red_SiR's Avatar
All Motor Mentor
190 LPh should be plenty...255Lph will obviously work as well but is mainly suited for boosted motors. Your engine is only gonna use so much fuel, excess goes back to the tank which is why it physically doesn't matter which one you use. If the 255 Lph is a lot more, I'd stick with the 190 Lph.
Old Dec 10, 2006 | 05:50 AM
JFG Kevin's Avatar
Default Re: Which Fuel pump is needed? (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">190 LPh should be plenty...255Lph will obviously work as well but is mainly suited for boosted motors. Your engine is only gonna use so much fuel, excess goes back to the tank which is why it physically doesn't matter which one you use. If the 255 Lph is a lot more, I'd stick with the 190 Lph.</TD></TR></TABLE>
Oh...i c...well i am planning to put nitrous later on, better get a 255 just in case...or even with nitrous i might not need it?
Old Dec 10, 2006 | 06:10 AM
00Red_SiR's Avatar
All Motor Mentor
I run nitrous on my car and it's a daily driver with the stock fuel pump and no problems at all. What you have to remember is that on a daily driver, your nitrous would only be "on" maybe 1% of the total operating time. The only nitrous system that places any real demand on your fuel system (other than a high power nitrous system) is a dry system. A 190Lph fuel pump is a decent upgrade over stock and will flow plenty for a nitrous application used on the street and some strip use. Boosted cars are "on" all the time and place a much higher demand on the fuel system consistently. A 255Lph pump wouldn't be mandatory for those setups until the power level gets up there, but it would be considered "better suited" for those applications.
Old Dec 10, 2006 | 06:56 AM
EG-B20vtec's Avatar
Just wondering why basic math indicates that stock fuel pumps are more than sufficient for mild to wild all-motor set-ups yet people continue to insist on upgrading them. I smell a conspiracy...j/k
BTW I put down 203/156(stock EX Pump 79lph, 310cc)
and 214/153 (Stock Dx Pump 79lph, 310cc)
Fact: Liters to Cubic Centimeters: 1 L = 1000cc's
Example 79 lph pump = 79,000 cc's per hour
So, 79,000 cc's per hour divided by 60 minutes = 79,000/60 = 1316.66 cc's min
So, 1316.66 cc's min/4 injectors = 1316.66/4 = 329.16 cc's min
Which is plenty large enough to support a 310cc/min injector.
In turn that would indicate that an upgrade to the 135lph would be all that is needed in most cases for a healthy buffer of fuel volume.
Example: 135lph x 1000 = 135,000 cc's/hour
135,000/60(minutes in the hour) = 2250cc's/min
2250/4 injectors = 562.5 cc's/min (Would support 560cc 's per injector)
Basically for all intents and purposes I will only refer to the majority of modified Hondas/Acuras.
Fuel Pump Ratings are as follows:
1988-2000 Civic CX, DX, EX = 79 lph
1989-2001 Integra RS, GS, LS = 79 lph
1999-2000 Civic SI = 135 lph
1994-2001 Integra GSR = 135 lph
1997-2001 ITR = 135 lph
Modified by EG-B20vtec at 10:44 AM 12/14/2006
Modified by EG-B20vtec at 4:04 PM 12/18/2006
Old Dec 13, 2006 | 09:28 PM
JFG Kevin's Avatar
Default Re: Which Fuel pump is needed? (EG-B20vtec)
hum...so you guys are saying that my stock GSR fuel pump is good enough for my all motor set up...
Stage 2
P&P gsr head
s2 IM paired with a holley 68mm tb
84.5mm or 85mm CP 11.5
Old Dec 13, 2006 | 11:09 PM
dude just upgrade the fuel pump to 255 and ur good to go
Old Dec 14, 2006 | 02:41 AM
JFG Kevin's Avatar
Default Re: Which Fuel pump is needed? (bLack*)
Why do it if it's not needed?
Old Dec 14, 2006 | 02:53 AM
koczeka's Avatar
Sorry for the questions, but what are the specs of a stock B16a or B18C fuel pump?
Is it a must to upgrade?
Old Dec 14, 2006 | 05:00 AM
RStoR's Avatar
Default Re: (koczeka)
Read this http://www.hondata.com/techfuelpump.html
Old Dec 14, 2006 | 05:36 AM
EG-B20vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koczeka &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the questions, but what are the specs of a stock B16a or B18C fuel pump?
Is it a must to upgrade?</TD></TR></TABLE>
Read MAN!!!
It's right there for the whole world to see.
As I said above...
Old Dec 14, 2006 | 05:40 AM
EG-B20vtec's Avatar
Default Re: (RStoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RStoR &raquo;</TD></TR><TR><TD CLASS="quote">Read this http://www.hondata.com/techfuelpump.html</TD></TR></TABLE>
So basically HONDATA believes as I do that if you use the stock fuel pumps at 32- 40 psi and only upgrade your injectors you will ample fuel to support your engine's requirements.
Great link...As it further underlines the fact that my math was correct.
&lt;&lt; Gives self a pat on the back.
Old Dec 14, 2006 | 08:54 AM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bLack* &raquo;</TD></TR><TR><TD CLASS="quote">dude just upgrade the fuel pump to 255 and ur good to go </TD></TR></TABLE>
dude you really dont need a damn 255lph fuel pump, thata OVERKILL
Old Dec 14, 2006 | 10:50 AM
koczeka's Avatar
Default Re: (EG-B20vtec)
I have read that article years ago.
With my question I just wanted to highlight that stock fuel pump might be adaquate for most of us.
Old Dec 14, 2006 | 08:32 PM
Default Re: Which Fuel pump is needed? (SkankyEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote"> dude you really dont need a damn 255lph fuel pump, thata OVERKILL</TD></TR></TABLE>
im running a 255 on a 2L motor, its fine
Old Dec 15, 2006 | 02:28 PM
00Red_SiR's Avatar
All Motor Mentor
im running a 255 on a 2L motor, its fine</TD></TR></TABLE>
All that means is that your engine's only using a certain amount of fuel that could easily be supported by a 135 lph stock fuel pump. At least 120 lph and more is just being sent right back to your gas tank through the return line.... That's money spent to just send more fuel back to the tank in reality...unless you're boosting and using an FMU, it's hardly worth it.
Old Dec 15, 2006 | 11:57 PM
JFG Kevin's Avatar
hum...i guess stock gsr fuel pump is good for 240whp+ from what i'm hearing..
Old Dec 18, 2006 | 01:16 PM
EG-B20vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFG Kevin &raquo;</TD></TR><TR><TD CLASS="quote">hum...i guess stock gsr fuel pump is good for 240whp+ from what i'm hearing..</TD></TR></TABLE>
From what I was saying at the top...there shouldn't be a question. Think for yourself a little. Read it this time...understand it...Stop Worrying!
Start with a 135 lph pump.
Convert lph to cc's...(Because we use cc's for Hondas)
135 x 1000 = 135,000 cc's per hour
Convert to minutes...
135,000 lph divided by 60 minutes = 2250 cc per min
2250cc divided by 4 injectors = 563 cc per min
SO THIS MEANS THAT A STOCK GSR PUMP WILL SUPPORT UP 550cc INJECTORS WITH NO FUEL DELIVERY ISSUES!
Old Dec 19, 2006 | 05:53 PM
JFG Kevin's Avatar
Good explaination....but sometimes numbers dont relate to how well something works...Especially electrical or mechanical, I'm just making sure that people have done it before and can tell me what they know about it. I'm rebuilding a motor and probably going to be my last motor build with Honda's i just want to do things right from the beginning.
Old Dec 19, 2006 | 06:10 PM
smileycvc's Avatar
a 255 walboro pump is only 104 dollars so why not get one if anything you may end up need it in a later build. Just like everyone else has said it wouldnt hurt anything so why not.
Old Dec 19, 2006 | 06:18 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Which Fuel pump is needed? (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">a 255 walboro pump is only 104 dollars so why not get one if anything you may end up need it in a later build. Just like everyone else has said it wouldnt hurt anything so why not. </TD></TR></TABLE>
Because as this thread clearly points out....it makes no sense to spend even one dollar let alone $104, just to send more fuel back to your gas tank....
Old Dec 20, 2006 | 01:18 AM
JFG Kevin's Avatar
Because as this thread clearly points out....it makes no sense to spend even one dollar let alone $104, just to send more fuel back to your gas tank.... </TD></TR></TABLE>
I couldn't put it any better...
b20vtech
Sep 5, 2007 12:40 PM
90si_mugen_crx
Apr 11, 2005 01:07 AM
COP BAIT
Feb 26, 2005 10:15 AM
BoostedsiR
Mar 9, 2004 09:05 AM
SupaFly_Honda
Dec 22, 2003 02:26 PM
