skunk2 stage2 cams Question????
Old Dec 8, 2006 | 08:53 PM
REDREXMANB16's Avatar
Default skunk2 stage2 cams Question????
I am build ls vtec and gunna run the sk2 stage 2 pro cams and was woundering what piston options i should concider i want to be able to handle 9000 rpm all day!!! if u know anything that could help let me know!!! OEM or aftermarket
Old Dec 8, 2006 | 09:35 PM
Boots's Avatar
Default Re: skunk2 stage2 cams Question???? (REDREXMANB16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDREXMANB16 &raquo;</TD></TR><TR><TD CLASS="quote">I am build ls vtec and gunna run the sk2 stage 2 pro cams and was woundering what piston options i should concider i want to be able to handle 9000 rpm all day!!! if u know anything that could help let me know!!! OEM or aftermarket </TD></TR></TABLE>
what head are you going to run on your ls/vtec?
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDREXMANB16 &raquo;</TD></TR><TR><TD CLASS="quote"> sk2 stage 2 pro cams</TD></TR></TABLE>
So are you running S2S2's or S2 Pro2's? BIG difference.
Old Dec 9, 2006 | 07:25 AM
i think they are the pros the part # is 305 -05 -1045 pritty sure
Old Dec 9, 2006 | 07:26 AM
Default Re: skunk2 stage2 cams Question???? (clean rice)
b16
Old Dec 9, 2006 | 07:31 AM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDREXMANB16 &raquo;</TD></TR><TR><TD CLASS="quote">i think they are the pros the part # is 305 -05 -1045 pritty sure</TD></TR></TABLE>
if they're pros is say go 12:1 or 12.5:1, but that me
Old Dec 9, 2006 | 07:32 AM
SkoundrelUSA's Avatar
cute little bastard
P73-00 JDM ITRs
Old Dec 9, 2006 | 11:37 AM
is those pistons and stock rod be able to handle 9000 rpm all day tho is the question!
Old Dec 9, 2006 | 10:41 PM
well if i used p30 they would give me more compression would those work? they are just the skunk2 stage 2 's not the pros ! it will be higher compression!
lsteg94
Sep 4, 2007 01:48 PM
Beau Gotti
Feb 22, 2006 08:57 PM
got_boost16
24
Jan 27, 2006 12:26 PM
b16vtecsol
Jan 4, 2004 01:48 AM
