Type r oil pump in LS/Vtec
Old Dec 8, 2006 | 08:10 PM
ganjasnack's Avatar
Default Type r oil pump in LS/Vtec
i was planning on building an ls vtec and upgrading the ls oil pump to a type r oil pump. if i do this will i have to use a type r oil pickup or can i use the ls oil pickup.
Old Dec 8, 2006 | 09:15 PM
turbod da's Avatar
Default Re: Type r oil pump in LS/Vtec (ganjasnack)
use the pickup that matches the oil pan.........so if u have a ls pickup use a ls oil pan
Modified by SNACH at 12:00 AM 12/9/2006
Old Dec 8, 2006 | 09:17 PM
qfast817's Avatar
Default Re: Type r oil pump in LS/Vtec (SNACH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SNACH &raquo;</TD></TR><TR><TD CLASS="quote">use the pickup that mathes the oil pan.........so if u have a ls pickup use a ls oil pan</TD></TR></TABLE>
Old Dec 9, 2006 | 05:53 AM
jduranclk's Avatar
Old Dec 9, 2006 | 10:09 AM
akandok's Avatar
you have to change main caps to gsr main caps if you want your oil pick up to bolt on. these parts only work together, ls main caps, ls pick up, ls oil pan. gsr main caps, gsr pick up, gsr pick up.
2low93
May 26, 2012 10:44 AM
ITRiWISH
Sep 28, 2008 08:40 AM
esoterEK..
Feb 22, 2007 09:36 PM
88whitehf
May 26, 2004 11:21 PM
B18PoweredCivic
May 26, 2003 06:17 AM
