Fuel Pump Wont Prime
Old Dec 8, 2006 | 05:51 PM
Pman92's Avatar
Default Fuel Pump Wont Prime
Hi all I'm new here so I hope someone can help. I have a 92 Lude with an H23 in it and about 3 months ago I pulled motor out to rebuild, 293k miles on her. I put a new walbro 255 fuel pump in it before taking engine out and it worked fine. Since then I have reinstalled motor, sleeved, forged rods and pistons, getting turboed.
The fuel pump will not prime and I dont hear any clicking from main relay. I put on bigger injectors 450cc blue tips, obx fuel rail, obx adjustable fuel pressure regulator and no fuel. Motor turns over but no pressure showing on regulator gauge at all. Tested wires coming out of pump and had nothing. Have a good ground showing at relay also. Any help would be greatly appreciated.
Thanks Pat
Old Dec 8, 2006 | 06:33 PM
md23vtec's Avatar
Default Re: Fuel Pump Wont Prime (Pman92)
Sounds like your main relay took a **** on you. Check your ground on the thermistat housing also
Old Dec 8, 2006 | 06:34 PM
y0whuddupb's Avatar
had a problem similiar to this.
id say. check your t-stat ground. swap relays just to be sure. and check the ground and power wire on the fuel pump.
Old Dec 8, 2006 | 07:20 PM
skinnyboy's Avatar
bench test your main relay, theres a section in the Manual that tells you how to do this.
I had a similar problem when i swapped out my f22 and H22'ed my car, the stock F22 pump wouldn't prime so had to swap it out for a H22 one, which fixed the problem. Something to do with the fuel pressure at the injectors.
Old Dec 9, 2006 | 11:48 AM
Pman92's Avatar
Thanks for the help peeps. It was the ground on thermostat housing that wasnt hooked up. She working now. I appreciate all the help.
Old Dec 9, 2006 | 04:56 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pman92 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help peeps. It was the ground on thermostat housing that wasnt hooked up. She working now. I appreciate all the help.</TD></TR></TABLE>
Glad we could be of help Goodluck with the motor on the new rebuild
EG92DX
15
Jan 23, 2013 09:41 AM
CRJenkins13
Dec 4, 2007 06:52 PM
JDMlyfestyle
25
Oct 16, 2004 11:05 AM
SLOW4drINTEG
Jul 30, 2003 07:09 AM
CRXMATT
Mar 20, 2003 06:01 PM
