lowered crxs and civics
Old Dec 8, 2006 | 04:32 PM
freshly boosted DOHC ZC's Avatar
Default lowered crxs and civics
how often do you guys go through tires on your lowered honda? how low are you guys and what tire do you run? my crx is eating up my kuhmo tires on the inside and i know i need a camber kit.
edit: kumho tires
edit 2: ultra high performance
KU31X ECSTA SPT XPT
Modified by almost boosted DOHC ZC at 6:05 PM 12/8/2006
Modified by almost boosted DOHC ZC at 6:21 PM 12/8/2006
Old Dec 8, 2006 | 04:39 PM
1991hb's Avatar
I have the same set of tires on my car from when I first lowered it...that was almost 2 years ago. I'm running on Zexius tires
Old Dec 8, 2006 | 04:45 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (1991hb)
I have a camber kit my last set of tires got around 40k.
current set only has a few thousand, and my slicks... they don't last long anyway .
Minh826's Avatar
Default Re: lowered crxs and civics (almost boosted DOHC ZC)
I have a 89 civic with Tein SS Coilover set-up, Yokahama AVS ES100(195/50r15) and a good alignment. I don't even have a camber kit and It's been 5 month of hard driving and barely any inside wear. If you get your toe adjusted straight out on the alignment, you can save alot of tire wear. It won't be perfect as a stock car but it will help you out alot...Here is some pics for your reference..
Old Dec 8, 2006 | 04:55 PM
user 98292739's Avatar
i have no gap all around on my crx and im still running on the same tires 2 years ago.
you need a alignment thats it. go get it and eveerything would be solved. if they ask you about camber tell them dont worry about it just fix the toe in/out.
Old Dec 8, 2006 | 04:59 PM
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">i have no gap all around on my crx and im still running on the same tires 2 years ago.
you need a alignment thats it. go get it and eveerything would be solved. if they ask you about camber tell them dont worry about it just fix the toe in/out.</TD></TR></TABLE>
i did get an alignment and my tires are still getting worn down hella fast on the inside tires are only like 5 months old with about 10-15000 miles on them
Old Dec 8, 2006 | 08:26 PM
Default Re: (almost boosted DOHC ZC)
no finger gap really and no tire wear and i drive like an *******. I do have a camber kit but my camber kit maxed out and my camber is over the min cause im to low.
i say take it to a good alignment shop. DOes your car pull left or right? or steering feel funny?
Old Dec 8, 2006 | 09:44 PM
it was at a good alignment shop. it was pullin to the right but that was fixed. steering is just fine. and my car is just about as low as yours in the front anyways.
but when i took my car to the shop they said they couldnt really do anything about the front camber. but the dude said he did as much as he could.
oem mud flaps FTW
Old Dec 8, 2006 | 10:02 PM
jdm_ef9_b16's Avatar
buy you a set of neo gens. nittos. they are good for excessive camber.
Old Dec 9, 2006 | 06:59 AM
Slystone's Avatar
Default Re: (jdm_ef9_b16)
these are Rota Grid wheel?
Old Dec 9, 2006 | 08:09 AM
408wdy's Avatar
Default Re: (Slystone)
im tuckin tire front/back.. and so far the fronts have lasted 7 months. yoko avs es100
Old Dec 9, 2006 | 03:54 PM
yup those are grids.
i also forgot to mention im running 205/50/15 in the front.
you really shouldnt have inside wear unless you autocross with them alot.
since your sol so far i would just try another shop and see what they say. cause i am couple degrees over the recommended camber even with my camber kit but i still dont get any wear.
Old Dec 9, 2006 | 03:59 PM
Default Re: (408wdy)
cliick on pic to make larger
here shows it being lower then that first pic.
Old Dec 9, 2006 | 04:52 PM
djphonics's Avatar
Lobster, your car looks sick.
Old Dec 9, 2006 | 05:14 PM
janz3n's Avatar
Default Re: (djphonics)
my cars not lowered and i got huge camber wear then got an alignment and new tires and so far nothing.. im worried about when i lower my car. tires are expensive
Old Dec 11, 2006 | 03:13 AM
JohnnieChimpo's Avatar
Default Re: (janz3n)
How many miles are on your suspension pieces?
It may need upper and lower ball joints, and/or inner and outter tie rods, maybe even struts. Worn out components eat tires.
I know I got my car aligned and it felt better but after a week or two it started to pull again.
Old Dec 11, 2006 | 09:15 AM
janz3n's Avatar
Default Re: (JohnnieChimpo)
my alignment was done a couple weeks ago and is still great.. i do need one inner tie rod though.. which im getting fixed this week hopefully. also hopeing getting new bushings all around this week too. pretty srue my struts are good though. no noise except for the passenger side when i go over big bumpes.. but i think that might be a bushing issue but i could be wrong. i have new upper ball joints and as far as i know the bottom ball joints are original.
Old Dec 11, 2006 | 09:59 AM
fireant's Avatar
It very well could be a bushing issue. You can sport lots of negative camber with little to no side effects as long as you have ZERO toe, and your bushings STAY that way when you are driving. Old bushings will allow you toe to deviate.
Old Dec 11, 2006 | 12:07 PM
MasterShake's Avatar
im pretty low with major camber issues, i just cruise and i barley show any camber wear.
Old Dec 11, 2006 | 03:07 PM
1320spTurtle's Avatar
got alignment like late last year, hardly any camber wear since then. had mad camber issues previous to that, running 205's ES100's in the front and DZ101's in the rear
Old Dec 11, 2006 | 05:21 PM
408wdy's Avatar
Default Re: (1320spCRX)
Old Dec 11, 2006 | 05:28 PM
Mr.Death's Avatar
^^^^^God thats low^^^^
Old Dec 11, 2006 | 05:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 408wdy &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Hey you were at the EF meet @ MT. Hamilton, your ***** ****** dumped. only rubs if you turn
Old Dec 11, 2006 | 06:22 PM
408wdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320spCRX &raquo;</TD></TR><TR><TD CLASS="quote">Hey you were at the EF meet @ MT. Hamilton, your ***** ****** dumped. only rubs if you turn </TD></TR></TABLE>
thanks bro. yeah that meet was cool, i got there kinda late though. maybe next time i can bring the crx.
Old Dec 11, 2006 | 06:23 PM
wiZCo's Avatar
Stouts 'n' Scotch
got alignment like late last year, hardly any camber wear since then. had mad camber issues previous to that, running 205's ES100's in the front and DZ101's in the rear</TD></TR></TABLE>
Damn, that's sick.
