Spoon front lower arm bar Q
Old May 10, 2002 | 08:19 PM
vtir's Avatar
Default Spoon front lower arm bar Q
For those with the Spoon FRONT lower arm bar, does it matter if you attach it like the instructions with the bar below the brackets
OR can you attach it with the bar above the brackets? (like the rear one)
Having clearance problems..with humps etc
TIA
[Modified by vtir, 1:19 PM 5/11/2002]
[Modified by vtir, 3:58 PM 5/11/2002]
[Modified by vtir, 3:59 PM 5/11/2002]
Old May 10, 2002 | 08:22 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Spoon front lower arm bar Q (vtir)
Clearance problems with what?
Old May 10, 2002 | 08:41 PM
uNF$@#!'s Avatar
Default Re: Spoon front lower arm bar Q (Rguy)
this is the type R forum...are you asking on a type R or on a civic?
Old May 10, 2002 | 08:52 PM
uc0083's Avatar
Default Re: Spoon front lower arm bar Q (00-0187)
Below you can mount it above but it will rub on the header. Just be careful it sits very low and the brackets arent the toughest things in the world.
Old May 10, 2002 | 10:59 PM
vtir's Avatar
Bar is mounted on a DC2 but pic is for illustration.
The bar is same for DC and EK chassis anyway.
Old May 10, 2002 | 11:47 PM
GokuSSJ4's Avatar
really dont like the front ,specially went the car is way to low can you say ouch !
Old May 11, 2002 | 11:19 AM
NWPNOMORE's Avatar
Banned
Default Re: Spoon front lower arm bar Q (Spoon1)
I had the front tie bar, but it sat way too low. One big speed bump and your bar is bent.
Old May 11, 2002 | 11:21 AM
EleanoR's Avatar
Default Re: Spoon front lower arm bar Q (NWP4LIFE)
Yes i had this bar on my car and it sat wayyyy to low. I was on the stock suspension as well in my ITR. It bent several times and i always drive slow over speed bumps. I can't imagine where it got bent because the speed bumps i did hit were small. On a second thought, i had to use washers to get the bar even lower to clear the DC header. What a pain in the *** mod it was for not so much of a benefit in my car!
csufweed
Jun 9, 2002 01:07 PM
JDMchris
Jun 6, 2002 09:18 PM
Integra_Boi
Mar 20, 2002 06:13 AM
