Question about ECU
I just put a SOHC ZC motor into my CRX Si and I was wondering if the ecu from my D16 would work with the ZC that ive put in...the reason im asking is the motor isnt pulling how it should and i feel like its bogging down...
My other question is I am able to get an ECU out of an integra but the motor in it is a DOHC...just wondering if I would be able to use the ecu out of the integra with the ZC
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhistPriest87 »</TD></TR><TR><TD CLASS="quote">I just put a SOHC ZC motor into my CRX Si and I was wondering if the ecu from my D16 would work with the ZC that ive put in...the reason im asking is the motor isnt pulling how it should and i feel like its bogging down...</TD></TR></TABLE>
SOHC ZC = D16A6 = PM6 (CRX Si) ECU.
If your car is an Si, use the Si ECU.
Thanks</TD></TR></TABLE>
If they ECU says PG7, then yes, you can use it. It will run a little richer than the PM6 and will have an extra 700 rpm in it.
Just use the PM6.
Just use the PM6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhistPriest87 »</TD></TR><TR><TD CLASS="quote">ok thanks a lot
No problem buddy.
</TD></TR></TABLE>No problem buddy.
4door93civic
Jun 4, 2004 09:42 PM
BeEfiEBuNz
Oct 18, 2002 08:44 PM
