Anyone using the new hankook RS2's?? How do they compare to azenis?
Old Dec 8, 2006 | 12:28 PM
b18LS's Avatar
Default Anyone using the new hankook RS2's?? How do they compare to azenis?
Hi, guys as the title states? any thoughts? Are they worth the extra bucks? Thanks
Old Dec 8, 2006 | 01:06 PM
vtecsi00's Avatar
Default Re: Anyone using the new hankook RS2's?? How do they compare to azenis? (b16gs)
not as good as the azenis on dry traction but better on wet traction.. if all you care about is good dry traction and you don't live in cold climate then i would get the azenis 615....i sold my hankook rs2 and i just ordered my 615 yesterday
Old Dec 8, 2006 | 03:09 PM
b18LS's Avatar
Default Re: Anyone using the new hankook RS2's?? How do they compare to azenis? (vtecsi00)
Thanks for the reply. I guess that said it all! I think for the price of them It'd be worth going to the 615's. I've got two worn out Toyo T1s's and two good ones. I may look into replacing the two bad ones with new toyos as well. It looks like theyre dry traction is as good as the hankooks, but maybe not the azenis.
Old Dec 8, 2006 | 03:31 PM
vtecsi00's Avatar
if it's the t1r toyo then similiar if not then the hankook is better
Old Dec 9, 2006 | 04:12 AM
b18LS's Avatar
Its actually the T1s. I've heard the new T1R's dont have the same dry grip. I love the S's, but theyre damn hard to find now. what are your thoughts on replacing two S's with two T1R's and have a missmatched set. Theyre a similar tire, but the car will see track use.
Old Dec 10, 2006 | 05:10 PM
MatMattMatthew's Avatar
Im pretty sure i saw a shootout in Grassroots magazine and they rated the RS-2 higher than the Azenis. This was testing tires for street/autox
Old Dec 10, 2006 | 09:33 PM
super_nguyen's Avatar
Default Re: Anyone using the new hankook RS2's?? How do they compare to azenis? (MatMattMatthew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MatMattMatthew &raquo;</TD></TR><TR><TD CLASS="quote">Im pretty sure i saw a shootout in Grassroots magazine and they rated the RS-2 higher than the Azenis. This was testing tires for street/autox</TD></TR></TABLE>
i seen that article and im positive that the azenis came out on top, both the 615 and the discontinued 215 beat the rs2.
Old Dec 10, 2006 | 11:19 PM
vtecsi00's Avatar
Default Re: Anyone using the new hankook RS2's?? How do they compare to azenis? (super_nguyen)
the falken 615 has better dry handling then the hankook rs2 i have had them both like most of us...
Old Dec 11, 2006 | 03:17 AM
Mike_C's Avatar
http://www.grassrootsmotorspor...t.pdf
Old Dec 11, 2006 | 06:11 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16gs &raquo;</TD></TR><TR><TD CLASS="quote">Hi, guys as the title states? any thoughts? Are they worth the extra bucks? Thanks</TD></TR></TABLE>
For almost all purposes, I would go with the Azenis 615's.
The Hankook compound is very good. However, you will notice two things when you put 215-45-16 Hankooks next to the same size Falkens.
1. For the same size tyre, the Hankook is going to tend to have a smaller real world width.
2. The Hankook <u>tread</u> design puts less actual rubber contact patch on the ground. I think that they were so set on improving on the Azenis 215's wet performance that they over did it, providing much more channeling than they actually needed, with the end result that the overall grip is reduced.
My subjective opinion is that the Hankook compound is quite good. If they'd consider a tread redesign, I think they might equal the 615's in the dry.
95_red_dc
Jun 1, 2006 12:33 AM
b16_madman
Sep 28, 2004 02:58 PM
BAZ
54
Mar 5, 2004 05:48 PM
tygsr
Apr 5, 2003 06:49 AM
bus stop
10
Mar 28, 2002 07:34 PM
