Suspension & Brakes Theory, alignment, spring rates....
H&R race springs w/ 205/50/15 tires will rub on 99 civic?
Old Dec 8, 2006 | 11:52 AM
FLYNLOW's Avatar
Default H&R race springs w/ 205/50/15 tires will rub on 99 civic?
I was wondering if anyone w/ a similar set up has any problems w/ rubbing issues? Pix would help a whole lot Thanks in advance
Old Dec 8, 2006 | 12:12 PM
FLYNLOW's Avatar
anyone?
Old Dec 8, 2006 | 12:16 PM
BuiltforSin's Avatar
bump for VA member.. also interested in answer. im looking at these springs aswell
Old Dec 8, 2006 | 12:36 PM
chrisw85's Avatar
It will almost primarily depend on what offset on the wheels you are running and the width of the wheels. I'm riding on GC/Koni setup dropped to about where race springs would drop (in the rear that is), 15x7 +45mm wheels and 205/50/15 ES100 and no rubbing, you will probably rub if you have +38 wheels but a little fender rolling will do, the rears will rub more on the fender lip than the front.
Old Dec 13, 2006 | 05:01 PM
Mikes2000civicsi's Avatar
Default Re: (chrisw85)
yes it will,had em on mine
Old Dec 14, 2006 | 08:53 AM
alwaysoverkill's Avatar
depends on offset as mentioned. The drop alone will not make them rub.
Old Dec 14, 2006 | 10:13 AM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: (alwaysoverkill)
drop alone will not make ti rub it's the rims. I had wide rims with 205/50/15 and they did rub but if i used say a SI 15" i do't think it would have rub so it's the rims
Old Jan 4, 2007 | 02:47 PM
yo0n's Avatar
New User
Default Re: H&R race springs w/ 205/50/15 tires will rub on 99 civic? (FLYNLOW)
i have them on a 2000 civic and it will rub with the 205/50/15 .. but i fix my problem by buying new tires 195-50-15 .. it looks great !
TSAngry
Feb 10, 2004 05:55 AM
weakGOODJunKieS.com
Apr 5, 2003 10:05 PM
91civicdx
Mar 25, 2003 05:29 PM
Seedc2
Feb 27, 2003 02:43 PM
Integra21
Nov 10, 2002 12:04 AM
