Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
anyone amp the stock speakers?
Old Dec 8, 2006 | 09:56 AM
N4me (06civicsi)'s Avatar
Default anyone amp the stock speakers?
anyone use an amp 2 up the power of the stock speakers using a 4 channel amp?
Old Dec 10, 2006 | 02:02 PM
mooseheads36's Avatar
Default Re: anyone amp the stock speakers? (N4me (06civicsi))
bump....no one has done this?? i was thinking of doing it myself...
Old Dec 10, 2006 | 02:20 PM
Rahxephon's Avatar
350 watt is plenty juices for my Geezer's ears
Old Dec 10, 2006 | 05:13 PM
anyone???
Old Dec 10, 2006 | 05:37 PM
WILD_WILL's Avatar
Default Re: (N4me (06civicsi))
You can do it i use to do alot of car audio but havent in a while but you will need a line in/out converter mention that to someone in bestbuy or a audio place and they will hook you up.
Old Dec 11, 2006 | 01:37 AM
Demonis's Avatar
Im going to buy some new speakers later and amp those from the stock radio... but for now they are good enough as is.
Old Dec 11, 2006 | 07:00 AM
RICO_'s Avatar
NO MERCY!
Default Re: (Demonis)
Would definitely not recommend amping the stock speakers unless it's a really small amp. Stock speakers aren't designed to handle alot of continuous power. And that lovely 350 watt system is rated at max power, not continuous. Run 350 watts for a long period of time and you'll need new speakers in a hurry. Best bet is to get brand new speakers (I prefer FOCAL) and put a good amp to them. You'll be alot happier
Old Dec 11, 2006 | 12:09 PM
Hellzcivic's Avatar
My recommendation, if you want to upgrade your system, would be to replace your speakers first. The stock system already has an amp. I believe that amp is separate so you can hook different speakers too it.
If you want to replace the amp, you will have to bypass the stock amp, which I am told, is not easy if your keeping the stock head unit.
Anyway, the stock speakers are matched to the stock amp, if you change amps there is a good change your blow the speakers.
EM2abe
Audio / Security / Video
70
Dec 17, 2010 01:42 PM
gixxer508
Jul 29, 2010 04:37 PM
GetSmoked
Mar 11, 2005 03:20 PM
Reid
Oct 14, 2001 06:56 PM
William
Aug 9, 2001 07:22 PM
