how do you take out roof rubber/rain gutter thingy...??
This is how it's done on a hatch (the CRX may be a little different);
Use some pliers to grab the very end of the plastic (rubber) piece and pull it slightly rearward and upward. This will get it off the clip and metal pin that is under it.
Then gently pull the piece upward and out of the groove. The metal groove has a taper to it and that helps keep the piece in place.
There is another plastic clip and metal pin at the front.
As was said in one of the prior posts, the plastic piece has a metal piece molded in it and you should be careful to not bend it too much.
As for what it does; it's nothing more than a "cover" that hides the seam where the metal body panels are welded together. Even if you don't re-install it, there should be no problems with leaks. This assumes that the factory seam sealer is in good condition.
Wes
Wes
Quik89Si
Mar 5, 2006 06:48 PM
theemaddhatterr
May 13, 2005 06:42 PM
