Suspension & Brakes Theory, alignment, spring rates....
KYB agx struts and boots
Old Dec 8, 2006 | 07:54 AM
down_the_hatch's Avatar
Default KYB agx struts and boots
I bought a set of AGX's and also a set of boots for them. But since i'm using coilovers on my AGX's, it looks like I can't use the boots now because they won't fit. Has anyone had this problem? Can I at least use the "built-in" rubber bump stops on the boots if I cut them off? I did really want to use the boots to protect the strut.
Old Dec 8, 2006 | 10:59 AM
bmoua's Avatar
if you use coilovers, they wont fit. Are the boots you bought from kyb? or stock boots? i tried using my stock boots on my agx's with ground controls and it didnt' work. All in all its been 1 year and i've had no problems with my setup...
Old Dec 9, 2006 | 07:05 PM
Default Re: (bmoua)
i bought KYB boots which are rubber. stock honda ones are just metal cylinders, those work but they always get caught up onto the coilovers when I lower the car back down after working on it. pretty much i cant use dust covers/boots at all, but the question was, can I cut off the built in bump stop on the KYB boots? does anyone know?
Old Dec 15, 2006 | 06:24 AM
Default Re: (down_the_hatch)
bump
down_the_hatch
Dec 19, 2006 08:41 AM
sheBangZ
Sep 1, 2006 06:49 PM
Kowalski
Suspension & Brakes
Mar 27, 2005 03:24 PM
Nocturnal
Jan 17, 2004 12:35 PM
Nocturnal
Dec 17, 2003 01:10 AM
