crx with zc, converting to obd1 poss to keep my distributor?
ive come across a chipped p28 ecu and id like to convert my obd0 dohc zc to obd1 but since the zc uses that stupid cam sensor on the other cam its gonna be hard to find a dizzy for it.. is there any way i can wire the obd1 ecu up and be able to keep my obd 0 distributor or no ?
The obd1 distributors have a different number of 'teeth' inside compared to obd0 ones.
You can't run an obd1 dizzy on an obd0 ecu, or vice versa.
just get a distributor for the OBD1 ZC - it is a TD43U - remove the cylinder sensor and install a plug from a B18A1
http://www.andale.com/stores/s...ode=1
http://search.ebay.com/search/...earch
Modified by jlicrx at 10:40 AM 12/8/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">just get a distributor for the OBD1 ZC - it is a TD43U - remove the cylinder sensor and install a plug from a B18A1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">would an obd 1 sohc vtec dizzy work with the zc? or a obd1 dx dist? </TD></TR></TABLE>
no
no
jtmoney2002
Aug 25, 2008 04:43 PM
crxzcracer
Mar 2, 2005 03:39 PM
