RSX wheel offset?
Old Dec 7, 2006 | 10:45 PM
wacer's Avatar
Default RSX wheel offset?
Hey i looked through a bunch of posts and couldnt find what i was looking for...so ill ask it here. I drive a 2004 RSX with tein coilovers. i wanted to get work emotion's in 17's. Now to my question i was wondering what width and offset i should go so its flush. Also what size tires so that they're somewhat stretched?
Old Dec 7, 2006 | 10:51 PM
r.wright's Avatar
Default Re: RSX wheel offset? (wacer)
i would do like 17x8 +43
225/45
Old Dec 8, 2006 | 10:53 PM
wacer's Avatar
Default Re: RSX wheel offset? (mrrlx)
I was told that lower the offset the wider the wheel sits out on the car...so isnt +43 pretty conservative? Im lookin for an extremely aggressive stance. Further explanation would be great. Thanks
Old Dec 9, 2006 | 09:26 PM
Mike_C's Avatar
you're correct... for instance, a 0 offset would sit 43mm further out than a +43. your best bet is to ask in the RSX forum, but be forewarned you're not going to be able to be lowered much with an "aggressive" offset.
Old Dec 10, 2006 | 03:45 PM
mizjif's Avatar
i have seen RSX's run +35 offsets and it looks very agressive. then you have to start worrying about rubbing etc. depending on wheel width and tire size. i'd run more like a +40 offset if you wanted to run a fatter tire or rim without causing issues. Here is a link to wheel sizes and offsets that RSX owners have used.
http://forums.clubrsx.com/showthread.php?t=368629
Old Dec 10, 2006 | 05:03 PM
wacer's Avatar
Default Re: (mizjif)
great link thanks!
wacer
Dec 10, 2006 05:07 PM
3vilMonkey!
Jul 19, 2005 11:12 PM
Spork Sports
Aug 13, 2004 02:30 PM
sjracer
Dec 12, 2003 11:05 AM
Scorpaznatica
Oct 13, 2001 01:03 AM
