just got my gsr rod bolts for my h22 having problem
Old Dec 7, 2006 | 06:30 PM
h224thgensedan's Avatar
Default just got my gsr rod bolts for my h22 having problem
I did some research and i found that arp gsr rod bolts will work on h22 rods so i went ahead and got some well i am having problems getting the rod caps to go back on. I was wondering if you guys knew of any tricks for this other than hitting it back on and running the risk of damaging the threads.
Old Dec 8, 2006 | 01:15 AM
ExospeedAMcrx's Avatar
Default Re: just got my gsr rod bolts for my h22 having problem (h224thgensedan)
ARP bolts dont usually just bolt on to stock rods. You have to resize the rods to make them fit properly. Have to take it to a machine shp to do that.
Old Dec 8, 2006 | 05:48 AM
Default Re: just got my gsr rod bolts for my h22 having problem (exospeedAMcrx)
I called my local machine shop and he told me that he wouldnt do it with the pistons still on the rods. I told him that the pins were pressed and he didnt want to do it for me i dont know why. He just told me to put the nut on the bolt and tap it out and then put the new one in as far as i could and then put the cap on and tighten it up until it pulled the rod bolt in. Well i did that to one of my rods and i got the cap back off but now it doesnt want to go back on.
Old Dec 9, 2006 | 04:02 AM
alterdcreations's Avatar
find a new machine shop
Old Dec 9, 2006 | 07:55 PM
Default Re: just got my gsr rod bolts for my h22 having problem (alterdcreations)
yea no kiddin he is the only one in my area with in 75 miles.
Old Dec 10, 2006 | 07:54 PM
MassScene's Avatar
slide the rod bolt in from the top of the rod journal. then pry down on end of bolt with pry bar. It should snap in all the way.
Old Dec 12, 2006 | 06:19 PM
The rod bolt is in just the cap isnt going on and my local machine shop wont resize my rods.
VolkswagenWHO!!!
Sep 15, 2008 07:03 PM
Tony the Tiger
Aug 30, 2008 12:55 AM
JDM JEFFREY
Sep 25, 2007 05:52 AM
b2Ovtec
11
May 11, 2004 12:51 AM
michael O
Jan 6, 2004 08:57 PM
