How do you reset Oil Life indicator?
Old Dec 7, 2006 | 03:03 PM
hometheaterman's Avatar
Default How do you reset Oil Life indicator?
I just changed my oil on my 06 Accord for the first time that I've done it. The very first the dealer did it since it was free. I used a Honda oil filter and Royal Purple oil. Is this a good combination or should I try something else next time? Ok well here is my problem. The oil life where it displays it where the odometer is if you hit that button a few times still says oil life 30%. How in the world do I reset this so it will go back to 100%? I couldn't find it in the manual and couldn't figure out how to do it. Although maybe I wasn't looking in the manual in the correct place idk as I find it hard to believe it isn't in there.
Old Dec 7, 2006 | 03:06 PM
Honda-Master's Avatar
Default Re: How do you reset Oil Life indicator? (hometheaterman)
it is in the owners manual.. you just got to find the correct page and follow the directions
Old Dec 7, 2006 | 03:14 PM
Default Re: How do you reset Oil Life indicator? (Honda-Master)
I thought it would be but I couldn't find it on any of the how to change the oil pages. I guess I will have to look some more unless someone here knows how to do it.
Old Dec 7, 2006 | 10:28 PM
SuShiBoiiii's Avatar
uhhh turn the car off hold the reset button then turn the car on wait then it should be gone..btw its on the gauges page i think? correct me if im wrong but that for the 01 maybe its the same
edit sorry thought you said 00 haha newayz bump for an answer
Old Dec 7, 2006 | 10:49 PM
thatasiankidtony's Avatar
umm not sure if this would apply for your car but this is how you reset it on a Odyssey.
http://www.faqfarm.com/Q/How_d...yssey
orr
http://www.faqfarm.com/Q/How_t...hange
worth a shot...
Old Dec 8, 2006 | 07:25 PM
Default Re: How do you reset Oil Life indicator? (thatasiankidtony)
Ok thanks. I finally found it in the manual. I was looking around the oil change info but it turns out it was at the beginning of the maintence section. If anyone else is wondering how you do it you get it to display the oil life then you hit the odo reset button and hold it for 10 seconds I had to hold it about 20 for it to work although the manual said 10 and then let go and it should blink. Then you hold it for another 5 according to the manual I had to do about 5-10 a little over 5 seconds and it will reset it back to 100%. Thanks for all your help.
Old Dec 9, 2006 | 09:07 AM
epeen's Avatar
if its blinking a negative number or giving you updates as to how low you are.
dont matter if its on or off.
hold down the mileage reset while the oil % is showing. wait until it starts to blink itself, let go, and hold again until it resets.
presto
s2kc's
Honda Civic (2006 - 2015)
Oct 30, 2011 07:57 PM
Phatdl2o3
Aug 18, 2009 08:02 PM
bseries_ben
Apr 12, 2007 01:58 PM
TRAG
Nov 10, 2006 07:35 AM
Retselover
Honda S2000
Sep 19, 2003 06:53 PM
