Draw on my Battery?
Old Dec 7, 2006 | 02:39 PM
Mr.Speed's Avatar
Default Draw on my Battery?
Hello,
Can any one help? I have a problem with my 1998 Accord Coupe EX there is a draw on the battery and if it sits for about two days without driving it the battery goes dead!
I just put a new battery in the car and went back to make sure that the new battery is not defective and they check it out all is good with the battery.
I then checked the car for draws by disconnecting the negative battery terminal and putting a test light from the battery negative terminal to the ground wire and the test light lights up brite?
Has anyone had a problem like this before does anyone have any ideas where to begin?
I have disconnected the radio and checked to make sure all interior lights are off and that the trunk and glove box lights go out as well, they all do!
Any info would be greatly appreciated!
Thx
Old Dec 7, 2006 | 05:11 PM
hondadude's Avatar
Default Re: Draw on my Battery? (Mr.Speed)
With the test light set up like you had it, start pulling fuses one at a time till the light goes out.
Have your radio code in hand and remove the back up fuse first.
Then when you find the fuse that shuts off the test light you can repost with the fuse #/ circuit name, and someone might be able to cough up a circuit schematic for you.
Old Dec 7, 2006 | 09:07 PM
Mr.Speed's Avatar
Default Re: Draw on my Battery? (hondadude)
Ok I will do that and repost, but a quick question for you you said remove the back up fuse first? Which fuse # is this fuse? And so I understand your post I just remove one fuse if light does not go out replace it and move on to the next on, is this correct?
thx
Old Dec 7, 2006 | 09:25 PM
lunarone's Avatar
what are you gonna draw on your battery? are you a graffiti artist? i bet you could make some good money doing that. it's a good original idea. make a website and then have people send in their batteries so you can draw on them. I want a little calvin and hobbes tiger on the top of mine with your autograph next to it. that would look tight and my sponsors would like it. i like to study so i can know everything about life. life has lots of complicated things in it. but it's good that you've come up with this original idea so now you can patent it and be set for life. maybe you can sponsor some kid one day and he will drag race his accord so you can pay for his motors too.
Old Dec 8, 2006 | 12:22 AM
tONE.steR's Avatar
* B A N N E D *
Use a fluke meter perform a draw test, unplug fuses like blower motor, auxilary fans, when the amperage drops on the meter you've found your draw.
Car has to be asleep when you do this if not you'll burn your fuse in your fluke. I use an inline fuse to prevent that.
Old Dec 8, 2006 | 11:12 AM
hondadude's Avatar
Backup fuse should be marked in the underhood fuse box
40 amp #54 Feeds power to fuses9,10,11,12,and 13 of the passengerside interior fuse panel
Old Dec 8, 2006 | 11:43 AM
raceACCORDingly's Avatar
put a DMM to your batt and start pulling fuses
tmoney123
Feb 11, 2010 11:36 AM
UrVtecIsLoud
Dec 7, 2008 12:09 PM
samp
Dec 4, 2006 11:05 AM
SpoonEk253
Nov 26, 2006 02:12 PM
1 Cam Wonder
14
Nov 17, 2004 08:21 AM
